Have a brake light issue...
Old Jan 16, 2008 | 06:01 PM
dan.benton's Avatar
I have tried everything. I have a 96 with a bad brake light. It's on the left side and every now and then it works and then it doesn't. I've tried taking of the old "grease" off the light socket, but, that has not helped. It still works when it wants. I even checked the wires all the way into the body, no shorts. Any ideas?
Old Jan 16, 2008 | 06:06 PM
mdacton's Avatar
I had a similar problem in a car a month or so ago. Turned out to be a bad turn signal switch.
Old Jan 25, 2008 | 08:04 AM
dan.benton's Avatar
I just encountered a new finding. When I bump the light fixture with my hand, the light comes on. Weird. I am no electrician, but is sounds like a short. Can that still be the turn signal switch. If so, how in the world do you change that?
Old Jan 25, 2008 | 09:37 AM
mdacton's Avatar
may be a bad plug or ground, you just have to take it apart and check it
Old Jan 25, 2008 | 07:53 PM
kallcium's Avatar
I have had that problem and just changing the bulb fixed it for me. Sometimes they are ready to go and the filiment makes contact then it doesn't (after I changed mine I whacked mine and the filiment finally broke fully) Also the two metal contacts can get loose either on the bulb side or the socket side.... so if changing the bulb doesn't work, check the socket and you might have to bend some metal tabs back if it has them or change the socket. One last thing if the contacts on the socket are dirty, take a pencil eraser and rub them... it will clean it. Hope this helps
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
