V6 to LS1
Old Mar 23, 2008 | 03:10 PM
Mymaro98's Avatar
V6 to LS1
How hard is it to wire up the car when u change it from an v6 to ls1 i have a 98 camaro
Old Mar 24, 2008 | 07:15 AM
2000GTP's Avatar
Its usually easier to find a junked donor car and swap over the needed parts and wiring harnesses. There is a company called Speartech that modifies factory harnesses to work with specific conversions as well.
Old Mar 27, 2008 | 07:51 PM
smithtim's Avatar
motor shouldn't be that hard to pull out - bolt in as the V8 has the same body etc.,. However, you are going to have to mess with wires and probbaly will need to buy a new CPU ( just to much pain to do it any other way, in my opinion). Also, keep in mind you probably will also need to get a new tranny.
I geuss I would agree with the above post but in a diffrent way; if you've got a LS1 engine sitting around somewhere and looking for a place to put it then it would probably be cheaper, and easier, for you to go find a dead V8 car at a junkyard or something ( maybee <1K if lucky), unless your like me and just looking for a garage project to keep you busy
good luck
Tim
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
