spark plugs
Old Mar 17, 2008 | 06:09 PM
camaroLevi's Avatar
Unhappy spark plugs
I was wondering if my starting problem could be due to me not putting anti-seize on the spark plugs, would this make my car not start ,....or even if when i gapped them (say i didnt gap em enough would that also maybe be the culperate as well?) (my cars in the garage again)....80(
Old Mar 17, 2008 | 06:21 PM
2000GTP's Avatar
Lack of antiseize will not effect the plug from operating properly, but they will be very hard to remove down the road. As for the gap, do you remember what you set them at? The car was running for awhile before this problem, right? If so, even if you had the plugs at some way off gap, I'm guessing you would have seen issues quite awhile ago.
Old Mar 17, 2008 | 07:46 PM
camaroLevi's Avatar
well i had them installed before i got the cat convt.2 months ago it started and now no starting at all , when the shop guy puy my old tb back in he said he had to do sumthing with the obII , to reset the tb , so i was like hmm no no dont, (thinkin he was gunna shut something electronic off). ..
Old Mar 18, 2008 | 06:32 AM
2000GTP's Avatar
Maybe a "relearn" procedure or something of that sort has to be done, that would be done with a scanner or GM Tech2 scantool.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
