Need some engine swap info
Old Nov 2, 2007 | 09:17 AM
crucescamaro's Avatar
I have a 95 camaro w/a 3.4L V6. The headgaskets are bad and need replacing (big bucks). I am considering swapping this V6 for a 3.8 Buick V6. How much of a difference is there between these two engines installation-wise? Will I need new engine mounts? Other parts? How much of the old 3.4 parts can I recycle into the 3.8? Any information or thoughts would be helpful!
Old Nov 4, 2007 | 08:09 PM
Tru2Chevy's Avatar
When you say Buick v6, are you talking about the 3.8 that is found in 80's Grand Nationals and the '89 TTA, or the 3.8 Series II in 96-02 F-bodies?
- Justin
Old Nov 5, 2007 | 09:51 AM
V6 swap
I meant the Buick 3.8 in 96-02 F-Bodies. After having read through some of the past threads, I've found that this type of swap isn't practical- new wiring harness as well as other new parts. I think I'll go either the rebuild route on my current 3.4 or just fix the head gaskets.
Old Nov 6, 2007 | 10:28 AM
black95maro's Avatar
if you really want to swap the engine, another 3.4 would be simply obviously but i think you should just pull the engine out the bottom change all the gaskets and throw it back up.
rocketman051894
Jan 30, 2015 03:23 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Not Dave
Dec 11, 2014 06:32 PM
