3.4 no fuel pressure.
Old Oct 27, 2007 | 12:59 AM
FatBoySpecial's Avatar
I replaced the fuel pump last weekend and Im not getting and fuel pressure at the engine. First of all the PCM wasn't sending a signal to the relay to turn the pump on so I bypassed it to get the pump to work. And theres no pressure up there. The fuel lines are good, no kinks and the filter is new. Any ideas?
Old Oct 27, 2007 | 04:00 AM
GRNcamaro's Avatar
3 things
1)either the pump isnt turning on
2) you have a block some where)
3) you forgot to put fuel in the tank when you were done
Old Oct 27, 2007 | 10:04 AM
black95maro's Avatar
i would figure out why the pcm isn't telling the pump to kick on. you can try going to a junk yard and getting another pcm exactly the same as yours and give that a shot.
Old Oct 27, 2007 | 11:25 AM
I got the pump to turn on and the tank is full of fuel. I've thought about getting another pcm but its giving the engine spark. I dont know.
Old Oct 27, 2007 | 09:41 PM
dangalla's Avatar
i am a little confused, do you have power at the relay? do you have power at the pump? did you forget a connector at the pump?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Mike 92LX
Jul 25, 2016 01:54 PM
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
Latronaxe
Apr 29, 2015 08:25 AM
GigaMp3z
Feb 20, 2003 02:57 PM
