Need Help with a fan...
Old Sep 1, 2007 | 09:43 AM
tomfitzgerald's Avatar
I've got a 1995 camaro with a fan problem... I have hooked the fan directly to power souce and verified it's working.. I took the cap off the relay and it is contacting at idle while temp is running high. I put a volt meter on the output (green and grey wires) from the relay/fuse box and I am not getting voltage where I think I should. Can the relay still not pass current in the closed position? Can the a/c high pressure switch and or temp sensor still inhibit the relay in the closed (contacting position)?
Any suggestions besides replace the wires?
Thanks for your time,
T.
94SLUG
Jun 11, 2009 10:58 PM
97ramairta
Feb 19, 2008 06:33 PM
