1994 V6 overheating...
Old Nov 4, 2007 | 08:16 PM
Drew5x2's Avatar
Exclamation 1994 V6 overheating...
Hi, I just purchased a 94 camaro with a v6 and a 5 speed. I knew that it had problems when I got it, now I need to figure out how to fix them. It overheated really quickly so I replaced the thermostat. That seemed to work for about a day with no problems. But now it slowly overheats when I drive around town. Also if I try to turn on the heater it bogs the engine down and kills it if I don't turn the heater back off. That might be a totally different problem but I'd like to know about that too. (good thing I got a sweet deal on this car) Thanks everybody
Old Nov 5, 2007 | 02:41 PM
Drew5x2's Avatar
ok so I replaced the radiator and it drives fine and doesn't go past half way on the temp gauge but when I sit and idle it slowly gets hotter...I'm not sure if the radiator fan is turning on...HELP PLEASE!!!!!
Old Nov 7, 2007 | 04:36 PM
avie928's Avatar
try to sit in front of the drive way ands dont have ur ac on and let it run after a few min look to see if you fan is turning on once it reach a lil past the middle or middle. also in the case of driving around in the city and it still starting to over heat just drive with the ac on because then the ac fan will come on and help to cool down the engine
PopoFormula
Oct 12, 2015 04:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
95_lt1_z28
Aug 30, 2015 06:17 PM
WPHIG2
Aug 27, 2015 06:37 AM
