battery drainage time to ask the experts for help
Old Jan 21, 2008 | 09:11 PM
bighash007's Avatar
Im having problems with my car battery. I changed out the alternator and battery. When in idle for minute battery gauge hits in red until i punch gas on pedal. Im wondering how is the charging systems (or batt. gauges) look at idle, and what the idle rpm is
Old Jan 21, 2008 | 11:07 PM
SupplySgt.'s Avatar
you should idle around 800-900 RPM. the battery should stay above the halfway mark at idle unless it's low. And you shouldn't have to punch the gas to get it to go to that point.
Old Jan 21, 2008 | 11:59 PM
mrmint69's Avatar
Could be real simple like corroded connections or even loose ones.
Old Jan 22, 2008 | 12:33 AM
bighash007's Avatar
like wires connected to the alternator or battery? could it be any other reason? like a short or ground?
Old Jan 22, 2008 | 12:34 AM
bighash007's Avatar
at idle my battery goes below half it gets to beginiing of red
Old Jan 22, 2008 | 10:33 PM
mrmint69's Avatar
I had battery connections that looked clean but there was a film that looked dull that keep it from making a good connection. I would go over everything you can check.
Old Jan 22, 2008 | 11:34 PM
bighash007's Avatar
i will Thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
liamcg97
Nov 25, 2019 05:55 PM
Gtpguy
Jan 26, 2015 04:50 PM
capebuf
Jan 13, 2015 07:22 PM
