another missfire issue
Old Jun 24, 2007 | 02:29 PM
82lt1ta's Avatar
ok well i am having a miss fire issue,
its wierd
its there sometime and not there other times.
sometimes when i shut the car off and turn it back on it miss fires.
so i replace the plugs and wires, didn't help
i replace the coils and the ignition module, didn't help
still there sometimes
hook snapon diag tool up tells me another issue with the cam sensor
replace that
still a problem.
so i test the cam sensor the pink and the pink and black wires good volts there
when i test the brown wire i get too many volt, i get 11 its supposed to have a max of 7 wtf,
so i go farther into it i jump the connecter with a paper clip to read codes this way i get no code 12 which would suggest bad pcm?
any help im lost
i have replace everything i can think of?
Old Jun 26, 2007 | 07:46 PM
Need4Camaro's Avatar
its wierd
replace that
still a problem.
any help im lost
Not sure man, I would try O2 Sensors and EGR Valve for the heck of it but there's no gauruntee that it will help...
Old Jun 26, 2007 | 09:53 PM
Gilliam91's Avatar
Have you tried making the connector on the Cam sensor tighter? also what is the code?
Last edited by Gilliam91; Jun 26, 2007 at 09:54 PM. Reason: needed to add something.
Old Jun 27, 2007 | 07:13 PM
82lt1ta's Avatar
see what i did, i swaped out another cam sensor becuase it said it was bad the volt meter did anyway.
didn't work.
and there is no code.... see thats the wierd part, no code at all.
originally there was a code 17 which is a cam sensor
Old Jun 30, 2007 | 05:57 PM
82lt1ta's Avatar
could it be my ecm?
Old Jul 4, 2007 | 04:34 PM
82lt1ta's Avatar
just to let you guys know it was my god damn injectors i will post pics to show you guys later!
Old Jul 7, 2007 | 09:49 PM
Garcia95's Avatar
so it was the injectors
i had a similar problem with my 95 3.4 scanned it and gave me the cam sensor so i replaced it and the problem continued. how can i check the injecters to see if they are working properly.
edman
Mar 13, 2015 09:39 PM
babyIroc87
3rd Gen / L98 Engine Tech
Aug 11, 2002 04:29 PM
OneBad98Z
Aug 6, 2002 03:23 AM
JurisAg02
West South Central
17
Jul 29, 2002 01:59 AM
