Multiple cylinder misfire Question..
Old Apr 4, 2008 | 10:35 AM
Munson's Avatar
Hi, My friend has a 96 camaro RS.. It started running like hell the other day and i scanned it with autotap and I got a code for low MAF frequency and egr pintle position.. The EGR code was on before this problem happened.. So we replaced the MAF after I checked the wiring and harness. The car immediately started misfiring on random cylinders. Anyone else had this happen before? Please help!
Old Apr 4, 2008 | 02:11 PM
Fuel Fire Desire's Avatar
When I got the "multiple cylinder misfire", it ended up being a bad ground.
....found that out after plugs, wires, and a coil pack.
Old Apr 6, 2008 | 12:05 PM
Munson's Avatar
weird. I just dont know what would cause this to happen after putting on a new MAF sensor.. How did you diagnose your bad ground?
Old Apr 6, 2008 | 11:06 PM
After replacing plugs, wires, and a coil....I said screw this, and had a garage look at it.
Old Apr 7, 2008 | 10:47 AM
19z28camaro02's Avatar
check to make sure that your wires didn't get sliced by a pulley or something, I got the p0401 when my PS pump chewed on the wires, but mines a V8 so IDK.
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
jayblev95
Sep 26, 2015 09:44 PM
