1995 3.4 and I need to change the thermostat
Old Oct 3, 2007 | 09:07 PM
deadasslast2004's Avatar
any pics on how to get to the screws on the driver's sdie or info on how to do this? I don't have anything that will fiit in this area. I have a swivel thin swivel socket but NO go and I have no idea how to remove the throttle body above it. I need some help on this one?
Old Oct 4, 2007 | 07:24 AM
shock6906's Avatar
It's not that hard, but it's easiest to remove the throttle body. At least that's what I found with my 93 3.4. And I don't really think this qualifies as advanced tech.
Old Oct 11, 2007 | 09:47 PM
black95maro's Avatar
you can get a swivel and an extension and snake it down behind the plenum. worked for me
Old Oct 13, 2007 | 01:09 PM
stevesport47's Avatar
I've got a 94 3.4L and I used a small socket wrench and went in from the passengers side and over the top of housing. Once you get it loose you have to use your fingers to pull the bolt. I pulled some of the junk away from the engine so I could reach in easier. The first time it was a lot of feel but I've since done it 3 more time and it gets easier. One tip is pull the top water hose off the housing before you do this.
calaban
May 18, 2020 06:43 PM
jmadoll
May 27, 2015 07:13 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
joe777107
Dec 1, 2014 09:32 AM
TheV6Bird
Aug 27, 2002 10:38 PM
