Can i take off my ecu on 92?
Old Feb 19, 2008 | 08:47 PM
92slo-maro's Avatar
I have a 92 rs v6 im putting a stroker motor in. What is the best way to bypass the computer? someone told me to hook up the motor and cut the rest of the wires. theres got to be a better way.
Old Feb 20, 2008 | 06:47 AM
2000GTP's Avatar
What kind of stroker motor are you putting in, a carbed SBC, TPI, TBI, LT1, something else? If you are going carbed, you can take out the PCM/ECU altogether, however, if you are staying fuel injected, you will need some sort of PCM since whatever platform you will be installing, the sensors, engine harness, and ECM will most likely not transfer over. Could you provide some more information on your setup please?
Old Feb 20, 2008 | 08:16 PM
92slo-maro's Avatar
92 ecu
it is a 71 model carburated w\ .060 over pistons, steel crank,cast heads w\202-160 valves and 58cc`s around 10.5:1 (not really a stroker}
Old Feb 20, 2008 | 11:57 PM
2000GTP's Avatar
Your exising wiring harness and ECU will be of little good then. Your best option then would be to get aftermarket gauges and see if you can rig up a decent looking instrument panel with them.
RUENUF
Mar 13, 2016 03:37 PM
SEOJustin
Sep 24, 2015 04:39 PM
Aug 7, 2015 08:52 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
