Likely source of oil leak
Old Aug 10, 2007 | 09:25 AM
DMGroh's Avatar
2000 V-6, 103000 miles, very well taken care of. I have a small oil leak that appears to be from the rear area of the intake manifold. It's pretty hard to see anything back there, so besides replacing an intake gasket, are there any typical causes of oil leaks from the rear top of this motor?
I have studied the Helm Manual, but can't see anything obvious. Thanks for any and all suggestions
Old Aug 11, 2007 | 09:05 AM
Garcia95's Avatar
is it the top or is it from the rear main seal
Old Aug 19, 2007 | 09:08 AM
DMGroh's Avatar
Above the heads. It ends up in the rear seal area, but it is migrating down from the intake manifold gasket or something up there in the rear top of the motor...like an oil pressure sending unit, etc.
Old Aug 19, 2007 | 04:41 PM
2000GTP's Avatar
Probably a leaking intake gasket, it is not uncommon.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
