L98's in Vettes
Old Jul 21, 2003 | 01:12 PM
Black6SpdTA's Avatar
L98's in Vettes
I know L98's came in vettes but what years? Thanks
-Rippin
Old Jul 21, 2003 | 01:56 PM
Zepher's Avatar
85-91 I believe.
Old Jul 21, 2003 | 02:26 PM
krazzycowgirl's Avatar
yeppers in 84 they were Crossfire injections which were the L93 engines.
in 85 they went with the L98 engines & in 92 they started wtih the LT1 engines One year before for they put them in the camaros.
Old Jul 21, 2003 | 05:56 PM
DanTheIROCMan's Avatar
Are the L98s in Camaros identical in power to the L98s in Corvettes? I thought I had heard at one time that the L98s in Camaros were slightly "de-tuned". Any truth to that? Also, anyone know what gears come stock in the 89 5.7?
Old Jul 21, 2003 | 06:48 PM
87DJP2001's Avatar
Corvette's always had more HP/TQ then the lower priced Camaro/Firebirds. Just GM's policy.
Rear gears for 1989 5.7 TPI were the BW 9-bolt with 2:77 standard & 3:27 as a option. They did have the best rear Disc brakes with the 11.655 rotors & PBR aluminum calipers and a parking brake that worked.
Old Jul 21, 2003 | 09:51 PM
How can I tell if my car has the 3.27 option? I think it does just by seat of the pants, but then again, these engines have so much torque that even a 2. something would get you off the line pretty quickly....
Old Jul 21, 2003 | 09:54 PM
Check your RPO codes.
-Rippin
Old Jul 21, 2003 | 09:57 PM
87DJP2001's Avatar
Check your RPO codes located on the underside of the console lid.
Then get them decoded on www.thirdgen.org. It will be
GH3 for 2:77 & GW6 for 3:27 gear ratios for the BW 9-bolts only available with the 350 TPI L98 engine.
Old Jul 21, 2003 | 10:33 PM
Turns out I have the 2.77 gears. That goes to show just how much torque these cars really have. I have a 99 Cobra with 3.73 gears and my IROC will clobber it off the line even with measly 2.77 gears! But, I'm thinking the 1st gear in the trans must make up for the 2.77 because 1st gear is already pretty short, even with 2.77 rears. Anyone know what the gear ratios are in the trans?
Old Jul 22, 2003 | 06:53 AM
87DJP2001's Avatar
Check out www.thirdgen.org Home page and go to Tech data. It will give all specifications that you want to know.
Old Jul 22, 2003 | 08:44 AM
IROC5.7TPI's Avatar
Just some more clarification on the Vette vs. F-Body L98....
1985 Vette had IRON heads and made 220 hp.
1986 Vette had ALUMINUM heads and made 235 hp.
all 1987-up Vettes had 245 hp. Mainly due to higher cam profile, aluminum heads and free flowing manifolds. The f-cars didn't get that much HP until 1989 with the dual cat option. But they still had IRON heads and a smaller cam
Old Jul 22, 2003 | 09:31 AM
Dual cats were an option? I thought mine had all the options available, but no dual cats. So what is my stock hp rating?
Old Jul 22, 2003 | 11:35 AM
IROC5.7TPI's Avatar
Should be 230 or 235. I don't recall off the top of my head.
Old Jul 22, 2003 | 12:47 PM
angel71rs's Avatar
I think I remember reading back in 89 that dual cats weren't available w/2.77 diff due to exaust resonance reasons. Single cat 89 L98's were 330 hp. My 89 Formula 350 is a twin cat w/3.27's. Ran a best 15 flat at local 4,100 ft alt track; about a 14.3 corrected. So it doesn't look like the 2.77 diff hurts performance at all. Tranny 1st gear is 3.06.
http://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Jul 22, 2003 | 01:02 PM
That 3.06 1st gear explains why the 2.77 doesn't hurt the launch. BTW, I think you meant 230 hp, not 330 hp...
I used to run at a local track (sea level) completely stock running low 14s. Actually, I might have had the chip in at the time which explains why my single cat was running what your dual cat was.
Tarizza
Sep 20, 2015 03:26 PM
89 Iroc-z28
Jun 30, 2015 11:19 AM
Ivan1
Jul 24, 2002 09:19 AM
IROCKER
Jul 5, 2002 05:02 PM
