difference in 86 and 87 rear ends?
Old Jul 23, 2003 | 10:37 PM
Rice Killer87's Avatar
i have an 86 disk brake rearend,10 bolt. since my 87 has drums in the rear,i want to install a 3.42 posi in the disk brake rear and install it on my car. my dad looked up the posi traction unit and said the prices for the 86 and 87 were dif. (the 86 was more expensive) whats the deal? can i just swap the disks onto my drum rear now and install the posi and gears on the 87 instead? whats the best way to go?
any help is appreciated
Old Jul 23, 2003 | 11:27 PM
stevem's Avatar
if your 86 has discs then its a 9 bolt borg warner diff
and your 87 is a 10 bolt
go to 9bolt.com to look up parts for it they are expensive
Old Jul 24, 2003 | 01:14 AM
Slow91z's Avatar
But if it's a 9 bolt it's strong as hell and you don't want to get rid of it.
Old Jul 24, 2003 | 04:06 AM
iroczinoz's Avatar
I have an 86 IROC and Disc brakes and I have a 10 bolt.
Old Jul 24, 2003 | 07:11 AM
87DJP2001's Avatar
Depends on the Gear ratio on the 86 & 87. If both are 10-bolts and are the same series carrier (2 vs 3) you should have no problem. Rpo G80 Limited Slip & J65 Rear Disc brake would cause the difference in price for the 86. Also if both are 10-bolts you can swap the Disc's for the rear drums. Advice make sure both rears are 10-bolts before swapping parts.
dawg irocz
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
