Pulley Queston
Old Jul 24, 2003 | 02:03 AM
cwalsh
Guest
Posts: n/a
Pulley Queston
Does anyone besides March make underdrive pullies for 3rd gen L98's. I am just trying to kick around some optons.
TIA
Chris
Old Jul 24, 2003 | 07:15 AM
87DJP2001's Avatar
Keep kicking the idea around, unless you want problems using underdrive pullies on a street car.
Old Jul 24, 2003 | 02:13 PM
slayer6x6's Avatar
I think im the only one who hasnt run into charging problems after installing pulleys
Old Jul 24, 2003 | 07:30 PM
lordmetalz28's Avatar
Smile
jet makes a good power pulley dynoed at 17hp and 13 pds of tourque. slayer please dont get mad im say it friendly!!!!
Old Jul 25, 2003 | 02:31 AM
cwalsh
Guest
Posts: n/a
I saw that BBK did also but I did not know Jet did either. As for charging problems were these in automatis or manual cars?
Chris
Old Jul 25, 2003 | 08:52 AM
teke184's Avatar
i never had any problems with charging (except when i turned my cooling fans on with a manual switch...but that's alot of power draw).
doesn't ASP make pullies...maybe that's only 4th gens...
Old Jul 25, 2003 | 06:07 PM
TheGreatJ's Avatar
If you want pulleys get the March "Power & Amp" pulleys. It's an underdrive crank pulley and an OVERdrive alternator pulley. This slows down all the other accessories while keeping the alternator up to speed.
Don't trust the "dyno proven" numbers....repeatability on a regular chassis dyno is terrible. I've seen back-to-back runs with no changes vary by as much as 15hp. Pulleys are NOT going to net you 17hp. I'd expect 5 at the flywheel tops.
Old Jul 25, 2003 | 08:31 PM
cwalsh
Guest
Posts: n/a
I have seen those but did not really want to get into spending $200 for pulleys
Old Jul 25, 2003 | 08:57 PM
slayer6x6's Avatar
I got mine for $50 on ebay
Old Jul 26, 2003 | 03:43 AM
cwalsh
Guest
Posts: n/a
I also found that TPIS offers them with a belt to boot!! Did you feel a SOTP difference?
Chris
Old Jul 26, 2003 | 10:03 PM
slayer6x6's Avatar
I noticed that the enginge reved a little faster, but I also did an aluminum driveshaft at the same time.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
