Code 32 pissing me off
Old Aug 4, 2003 | 11:00 PM
Pro
Guest
Posts: n/a
Ok, so I replaced a line (filled with carbon btw) going from the intake to the EGR. I dont smell fuel inside or outside the car AT ALL now (when it previously warmed up, the smell of fuel was identical to just pouring gas all over yourself).
So Im happy in that regard. BUT, code 32 keeps popping up. What else should I check out? Iv read that most of you just ignore it, but it's hard to when it just blinks in your face at night... Plus Im just in that mindset to fix something thats bothering me.
Appreciate it, you guys rock.
Old Aug 4, 2003 | 11:06 PM
shwine617's Avatar
did you reset ur computer? unplug the negative battery terminal for 5 mins then put it back on..also u mentioned it blinking at night..u still have the onboard code reader shorted???!! thats not good make sure you un short the terminal then reset the computer..what does that code stand for anyway??
Old Aug 4, 2003 | 11:15 PM
Pro
Guest
Posts: n/a
Hmm, sorry, didnt include enough info.
I did unplug the battery and let it sit for 10 mins. I went out and drove it, and after about 15 mins of highway driving, it came on again.
Sorry, didnt mean that it blinks...
And I did run a scan on it and it was a 32.
Im probably going to replace the gas cap tomorrow. (Its the original). Besides I hate having to use a key to open it.
Old Aug 4, 2003 | 11:23 PM
shwine617's Avatar
i never said i didn't belive you it was a code 32..but i don't know what a code 32 means..
Old Aug 5, 2003 | 01:11 AM
Pro
Guest
Posts: n/a
Oh, well it just means some sort of EGR system failure. Either electrical, vacuum leak, etc. And like I said, I had a hose replaced, and gases seem to be circulating very nicely now. But, there still seems to be a problem somewhere.
Old Aug 5, 2003 | 09:15 AM
shwine617's Avatar
maybe the EGR valve is bad?? did u change that? check for any cracked wires or vacuum lines, good luck
Old Aug 5, 2003 | 09:56 AM
Pro
Guest
Posts: n/a
EGR holds well, lines all good...
Old Aug 5, 2003 | 12:34 PM
Rice Killer87's Avatar
if u dont have emmissions u can plug the EGR valve. i have mine plugged b/c it went bad and i never replaced it.
Old Aug 5, 2003 | 02:35 PM
Pro
Guest
Posts: n/a
Hmm from what I hear, that would be kind of dumb to do.
Im not in emissions area, but in Texas it will be state wide soon. I am an inspector myself, so believe me.
Old Aug 8, 2003 | 06:11 PM
Pro
Guest
Posts: n/a
I got the car back today. They said they couldnt get the light to come on. Well after about 20 mins of driving on the highway it came on again.
But the car drives so good. What else could there be? They looked over everything (supposedly) and said it is all good. Is this a common problem (where the light just comes on for no damn reason)?
Pro
Guest
Posts: n/a
Old Aug 8, 2003 | 06:21 PM
92_RS_305's Avatar
What kind of motor and injection system is on the car? I have a 305 TBI and I had the same problem. I went and got a 14 X 3" Open Element w/ K&N filter and haven't had a problem with it since.
Old Aug 8, 2003 | 11:41 PM
Pro
Guest
Posts: n/a
All the info is on my website. Its a 91 Z28 with 5.7
rideordie
Nov 5, 2019 04:52 PM
Heathen1
Jan 2, 2016 04:27 PM
Bxlt1
18
May 27, 2015 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
