Headlight Dimmer Switch
Old Jul 31, 2003 | 06:35 PM
JCZ28's Avatar
The headlight dimmer switch on my 92 RS is acting odd. If you leave the wheel at a resting position (it does have tilt wheel) the switch won't engage . However, if you put downward pressure on the wheel or put it in the LOWEST (to where it is locked under the lowest setting) and use the switch it will work fine and the lights will switch from high to low beam.
Has anyone ever had this problem, and if so can you shed some light on how to fix it?
Joey
Old Jul 31, 2003 | 06:50 PM
TheGreatJ's Avatar
The dimmer switch is actually at the BOTTOM of the steering column. It's a little white can lookin thing with a rod coming out of one end. The trun signal lever moves the rod which actuates the switch. The switch has slotted holes for adjustment....loosen the 2 8mm bolts holding it to the column and see if you can slide it up a little to take the slack out of the rod.
Old Jul 31, 2003 | 06:56 PM
JCZ28's Avatar
Does the steering wheel have to be removed to access the bar or can I remove the plastic column somehow?
Old Jul 31, 2003 | 10:36 PM
JCZ28's Avatar
Ok I figured it out!! Thanks for the help Jason
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
