Need Help With T-56
Old Jul 23, 2003 | 11:49 AM
IrocinthatZ's Avatar
Need Help With T-56
Can anyone here please help me i have been looking everywhere for a used T-56 and cannot find one....
Does anyone know of a online source junkyard anything where i can find a complete t-56 transition kit???
PLEASE HELP
THANKS
James Lennon
Old Jul 23, 2003 | 03:41 PM
Black6SpdTA's Avatar
www.speedautomotive.com
www.thirdgenresource.com
Just a few. Have you posted in the Parts Wanted forum? Keep looking dont give up man.
-Rippin
Old Jul 23, 2003 | 07:00 PM
Thanks Rippin I already called thirdgen and they dont have anymore left and i was looking at this other one you listed do you know if that would come with everything needed to make the transition??
thank you
James
Old Jul 23, 2003 | 07:33 PM
TheGreatJ's Avatar
SpeedAutomotive's T56 kit doesn't include the 3rd gen crossmember or the console plate. Depending on what year your car is, you may also need a flywheel for a 2-piece rear main seal (Centerforce part# 700107) and either a speedo signal converter or a Cable-X box.
Old Jul 23, 2003 | 07:45 PM
I have a 89 iroc...... so what parts do you see me needing...and any estimated cost minus the 1500 would really help....
i appreciate it
james
Old Jul 23, 2003 | 09:43 PM
TheGreatJ's Avatar
It's a late-model engine so the LT1 flywheel will work. I think you'll need the LT1 starter also (not sure if the stocker will fit the bellhousing) which you can get from SpeedAutomotive for probably next to nothing. Get a crossmember from Spohn...he has a good design and a great price ($110.)
I can't remember what year they went to an electronic speedo, so I'm not sure which one you'll need, but either a Cable-X box (for mech. speedo) or an SGI-5 from Dakota Digital (elec. speedo) will take care of the speedometer issues.
Old Jul 24, 2003 | 01:22 AM
Slow91z's Avatar
electric speedo 90 or 91 can't remember but not 89
Old Jul 24, 2003 | 12:28 PM
TheGreatJ's Avatar
The SGI-5 won't do the job then. Run a search on this forum for the Cable-X, I can't remember the website but I know I've seen it come up here before.
Old Jul 24, 2003 | 01:19 PM
Are you serious this part is over 300$$$ come on now...isnt there any other way???
Old Jul 24, 2003 | 03:20 PM
Slow91z's Avatar
you've got to pay to play
Old Jul 24, 2003 | 03:22 PM
Jaysz28's Avatar
Well doing some research would be of some help here
Here is a tech article from www.thirdgen.org
http://www.skulte.com/T56.html
and here is another from www.poorformance.net
http://poorformance.net/tech/t56/t56.html
and yet another from www.sethirdgen.org
http://sethirdgen.org/t56.htm
Hopefully these will show you that this is an easy swap, but it isnt' a cheap swap.
I also see a T56 for sale in the classified section at least once a week. I check the boards twice a day, if not more.
Good luck
-Snowyz28
Old Jul 24, 2003 | 06:33 PM
TheGreatJ's Avatar
It's either that or $200 for an Autometer electronic speedo and if you go that route then you have to find a way to mount it that doesn't look goofy.
Or you could update the dash to the newer style that uses an electronic speedo and buy the SGI-5, but with the time it takes to swap the dash you won't be much better off.
Or you could pay $600 for a tailshaft modified to use a mech. speedo sender.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
treyZ28
Mar 28, 2003 01:03 AM
GreenMonster138
Classic Engine Tech
Mar 26, 2003 02:14 PM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
