Diff btwn 88/89 5.7 tpi throttle bodies
Old Jul 22, 2003 | 02:37 AM
JerryG 95Z's Avatar
What is the difference between throttle bodies from an 88 and an 89 5.7 tpi?
I see that the part numbers for aftermarket TB's are different for those two years. I have an 89 IROC but I want to buy a TB from an 88 Formula. Will it work?
Old Jul 22, 2003 | 06:18 AM
Aron213's Avatar
an 88 can work on a 89 but a 89 cannot work on a 88.
Its a IAC passage on the 88, the 89 and up do not have this passage
Old Jul 22, 2003 | 08:20 AM
JerryG 95Z's Avatar
That won't affect the way it idles will it?
Old Jul 22, 2003 | 12:10 PM
TheGreatJ's Avatar
Block off the passages with a plate and it'll be fine. Just make sure it seals good.....vacuum leaks are bad!
Old Jul 22, 2003 | 08:18 PM
Aron213's Avatar
there is no passage on the front of the plenum on the 89, so you have nothing to worry about!.
TheGreatJ...the passage is on the backside of the TB, no need for a plate cause it sits flush up againt the area of the plenum where the hole is already blocked.
Old Jul 23, 2003 | 12:34 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The throttle cable is different too. The way the cable connects is different on 85-88 and 89-92 throttle bodies.
Old Jul 23, 2003 | 08:57 AM
JerryG 95Z's Avatar
Thanks for all the info. Next question, does anyone have a good pic of the throttle linkage from an 88? The pic I have does not show the linkage very well.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
kennyirocz
Feb 7, 2015 11:41 PM
Jul 4, 2005 05:00 PM
