HSR going on
Old Jul 24, 2003 | 08:29 PM
mrr23's Avatar
HSR going on
http://www.fl-thirdgen.org/mrr23/mrr23-11.html
started it today.
Old Jul 24, 2003 | 08:32 PM
ZzBlacKzZ's Avatar
looks nice. keep up the good work!
Old Jul 24, 2003 | 08:35 PM
Black6SpdTA's Avatar
Awesome man! Looks like you opted for the polished version, or is that just the picture? Let us know how it goes, as well as dyno results
-Rippin
Old Jul 24, 2003 | 08:37 PM
mrr23's Avatar
actually it has been ceramic coated silver. as it says at the top.
Old Jul 24, 2003 | 08:39 PM
Sweet! Looks nice. Sorry I just went right to the pictures.
Old Jul 24, 2003 | 09:20 PM
Aron213's Avatar
Your ahead of me by about two weeks...Ive bought and paid for mine, its on backorder at Summit till around August 1st.
Old Jul 25, 2003 | 06:29 PM
Slow91z's Avatar
Are those your old fuel rails??I was under the impression that you had to buy Holley's rails.
Old Jul 25, 2003 | 07:23 PM
mrr23's Avatar
those are the holley fuel rails. i got the HSR from a fire sale. guy in our club got his car burned to the ground. so i got all the stuff. had the intake ceramic coated. going to paint the fuel rails black.
Old Jul 25, 2003 | 07:24 PM
Slow91z's Avatar
My bad.
Old Aug 5, 2003 | 10:36 PM
mrr23's Avatar
well big problem tonight with the new intake. popping and backfiring. kept hearing a grinding clicky noise. luckily not far from home. opened hood. headers glowing real red. thinking major vacuum leak. nope. heard what sounded to be rockers making noise on the passenger side. took valve cover off. nothing loose. started motor. no oil. looked at gauge. nothing. thought oil pump locked up. i've had it happen before from cutting my heads .030 and not shimming the distributor. removed distributor. turn oil pump by hand. not that. looked at distributor. it has been jumping off the oil pump shaft.
so, couple of thoughts come to mind. this distributor came out of a 1989 caprice 5.0L. shouldn't matter.
1. the pin inside the gear is higher than normal. will compare original distributor to new one tomorrow.
2. the distributor hole on the intake is higher than normal. causing the distributor to sit higher up off the shaft.
3. the boss for the distributor clamp is higher. causing the clamp to tighten down but not firmly hold the distributor down.
side note. person i got the intake from hasn't experienced this problem. so most likely it's a distibutor problem. so, look out for this guys.
Old Aug 5, 2003 | 11:13 PM
Slow91z's Avatar
Interesting...How does the distributor gear look?? Depending on your cam it may be made of the wrong material, making it wear, and possibly let it move/jump?? or maybe the gear is slipping on the cam not the oil shaft?? Take a look at the cam gear and see how it looks...I'm shooting in the dark here, but that's the only reason I can think of for the obviously very off timing and no oil pressure at the same time.
Old Aug 6, 2003 | 03:36 AM
Dirt Reynolds's Avatar
Then again, maybe it does.
Slow91Z might have a point. You have an '86 Trans Am flat-tappet engine using an '89 roller-cam distributer, perhaps theres an issue with the distributer/gear in this scenario.
Might be something to consider.
Old Aug 7, 2003 | 04:19 PM
mrr23's Avatar
no i don't. i'm not using the old 305 motor here. it's a roller 5.7L motor. possibilties are the boss for the clamp is too high letting it jump up. cam gear is in great shape. the cross pin in hte distributor you can see was just touching the intermediate shaft. so it was just barely in the groove. i can't see the caprice distributor being any different than the one in an f-body. it's the same. no length difference. so i'm having the distributor seat cut down .050 and solving this.
Old Aug 7, 2003 | 06:23 PM
Slow91z's Avatar
Just a thought
Old Aug 9, 2003 | 06:04 PM
mrr23's Avatar
ok went and looked this over one more time. took off the clamp because i would need to bend it to make up for the distance. to make up for cutting the distributor seat. wouldn't you know, the driver's clamp boss sits about 1/8" taller than the one on the passenger side. so, most likely the distributor jumped up and moved a tooth when i floored it. putting it back together now. will know soon.
