Rear End
Old Aug 2, 2003 | 01:49 PM
AndyD713's Avatar
Rear End
Heya, I have an 88 Z with a non-posi rear end. I wanted to change it out, but a friend told me that it might just be easier to switch it over to a posi gearing instead of dropping out the old and putting in the new. Any input? Thanks, Andy
Old Aug 2, 2003 | 02:20 PM
chevyman502bb's Avatar
if it were me, id do a total rear end swap.....considering im not too expeiienced with diffs i would just swap the whole *** end
Old Aug 2, 2003 | 02:21 PM
Chuck!'s Avatar
I did the whole rear from 2.73 non posi drum to 3.42 posi disc and Im real glad I did. 3.73s would have been nice, but I got the rear for $325 and gears would have been $100 used, $100 for a posi and then ~$150 for install, where as I did the rear myself. Plus the rear discs on a 91 rs just look real good
Old Aug 2, 2003 | 02:25 PM
mines a 2.73 posi drum......so does that mean i have non posi or do i have limited slit? its an iroc....
Old Aug 2, 2003 | 02:27 PM
slip*
Old Aug 2, 2003 | 03:39 PM
87DJP2001's Avatar
Aka Posi is Gm's name for a Limited Slip rear. One and the same.
Old Aug 2, 2003 | 03:59 PM
i know......but what i ment is i dont know if i have an open or limited slip (posi) rear end
Old Aug 2, 2003 | 04:08 PM
87DJP2001's Avatar
Well you could open it up to check or just check the RPO codes located on your console lid. Check for RPO G80 is the code for the Limited Slip
Old Aug 2, 2003 | 07:04 PM
aklim's Avatar
Opening the rear end cover is another way.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
