switching to carb
Old Jul 26, 2003 | 02:10 PM
hmccoy's Avatar
switching to carb
Hi
I have a 350TPI, 5sp and
I am switching to carb and would like to use a dual plane high rise manifold, does anyone know the max manifold hight that will fit under a stock hood. with a holley 4150 and what type of filter?
henry
Old Jul 26, 2003 | 06:45 PM
12Second3rdgen's Avatar
Re: switching to carb
Originally posted by hmccoy
Hi
henry
As long as you arent running vortec heads you should be fine with a Performer RPM and drop base air cleaner with a 3" element.
Old Jul 26, 2003 | 08:19 PM
doug791's Avatar
just a question what tranny do you have that youre running a 350 5 speed?
Old Jul 27, 2003 | 01:17 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Why do you want to convert a perfectly good TPI engine and go backwards to a carb???
Old Jul 27, 2003 | 04:04 PM
TPI is not the best induction method, even with upgraded runners/etc. SDPC2000.com sells a vortec headed TPI motor with the LT4 hot cam that dyno'ed 360 horsepower. That same motor dynoed by chevy high performance but with a speed demon carb and an rpm air gap intake dynoed well over 400 horsepower.
Old Jul 27, 2003 | 05:30 PM
hmccoy's Avatar
switching to carb
__________________________________________________
The car was originally a 2.8 V6 with a T-5, I swiched to 305 TPI
with the T-5, then I put 350HO crate motor in it added hp chip
24lb injectors, adj fuel pressure regulator and went thru
two T-5's and Two rear ends. I built another 350 and raised the
compression, and it screwed up the fuel curve it now runs lean
I am just tired of screwing with the injections system, The carb
is cheaper, simple to tune, makes more power, so I am going
to change the cam, I have a T-56 6sp and replace the rear end
with a 4:11, 9 bolt ford. up the RPM curve to 6500 go for about 430hp
and have more fun.
henry
Old Jul 28, 2003 | 03:13 AM
and have more fun.
henry
Whyd you replace the 350HO ? Mine was a solid 13.0 motor with an occasional 12.9/12.8.
Old Jul 28, 2003 | 06:40 AM
hmccoy's Avatar
switching to carbs
yea, mine ran real good also but my girfriend over heated it real
bad. (drove if 40 miles with no water) so i built another and changed the cam, heads, CR (ported 305 heads with large valves) now it runs lean WOT. I need a shop with a dyno to and the equipment to burn me a new fuel map. it wont turn up.
its a speed density system, with a TPIS chip. 24LB injectors.
henry
Old Jul 28, 2003 | 09:09 AM
Re: switching to carbs
henry
Was it the 350HO with vortec heads or the older one? There is no way that ported 305 heads are even going to touch vortecs.
IndyZman
Oct 22, 2015 02:17 PM
Kawi
Sep 28, 2015 09:01 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
