AIR FOIL tell me everything you know
Old Jul 22, 2003 | 04:23 PM
lordmetalz28's Avatar
what kinda specs am i looking at with adding an air foil i heard 40cfm and 6hp but probably not any really dyno reports about it ?
Old Jul 22, 2003 | 04:43 PM
unvc92camarors's Avatar
i heard they are good if theyre like 20$ or under
otherwise spend the money on something more mod-worthy
just spreading the wealth
Old Jul 22, 2003 | 07:08 PM
meaning a little hp as in 5 or less
Old Jul 22, 2003 | 09:16 PM
slayer6x6's Avatar
If you still have the stock intake you will not be able to tell the difference after you put it on, at least i didnt...
Old Jul 22, 2003 | 09:31 PM
how did your pulleys work for you can feel it good huh did it mess with your volatage im ordering the jet power pulleys so i need to know
Old Jul 22, 2003 | 09:59 PM
slayer6x6's Avatar
I noticed a small gain from the pulleys. The engine reved a little faster, but i also did the aluminum drive shaft at the same time. As far as voltage goes, at an idle with my lights on, the gauge reads a little below 13 but once you get going it charges fine. I just have the crank and alt. pulleys, I would imagine you would see a bit more of a gain if you also had the ps pulley. If you do a search on underdrive pulleys, this topic has been discussed about a million times with some good info.
94z28jbw
Sep 8, 2002 03:22 PM
ReznorZ28
Aug 27, 2002 03:53 PM
BM93Z
Aug 22, 2002 02:45 PM
turbo_Z
Aug 19, 2002 10:50 PM
NHSZ28
Jul 25, 2002 07:58 PM
