Plentum Porting
Old Jul 25, 2003 | 08:23 AM
slayer6x6's Avatar
Plentum Porting
Can someone please expain in detail what has to be done. There are restrictive walls on the side of the plentum and on the bottom. The if i grind the walls on the side, it looks like i will grind though the side of the plentum. Also there is a little hole behind the left port behind the throttle body on the bottom. Should I take caution not to disturb this hole. Will a dremel tool be enough to do the job? Any suggestions will be helpful.
Old Jul 25, 2003 | 09:32 AM
Slow91z's Avatar
If you grind them off you will go through the wall...you have to smooth them and round them, not remove them...Go to Thirdgen.org and do a search, they have a diagram and all.
Old Jul 25, 2003 | 04:55 PM
Ski89Z28's Avatar
Slayer, check this site out it has great pictures and directions: Porting Plenums
Old Jul 25, 2003 | 04:57 PM
Slow91z's Avatar
That the site...I found a link to that from thirdgen.org.
Old Jul 25, 2003 | 09:00 PM
slayer6x6's Avatar
Sweet! Thanks man, thats all i needed to know
Old Aug 2, 2003 | 08:45 AM
G-Racer's Avatar
Porting is my profession if you are interested.
Old Aug 2, 2003 | 05:57 PM
Slow91z's Avatar
Strerling huh?? Where is that I'm in Dover, DE...What's your prices look like for heads and/or plenum...Stuff like that.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
