Smoking when started
Old Aug 3, 2003 | 09:17 PM
shwine617's Avatar
I just had a rebuilt 350 put in my car about a year ago, In the morning or if the car sits for a while and i start it, It will smoke for like 3 secs, then Its fine. Is this normal or a problem?
Old Aug 3, 2003 | 09:18 PM
Black6SpdTA's Avatar
What color smoke? From the exhaust pipes I assume? Blue = Oil and White = Water
-Rippin
Old Aug 3, 2003 | 09:24 PM
shwine617's Avatar
its white, is that bad? I think water in the exhaust is normal??
Old Aug 3, 2003 | 11:02 PM
96LT14u2Nv's Avatar
an excess of water in the exhaust would point to a possible blown head gasket.
Old Aug 3, 2003 | 11:53 PM
kickin's Avatar
Try nicorette.
Old Aug 4, 2003 | 10:53 AM
shwine617's Avatar
I know its not a head gasket, it only smokes for like 2 seconds only when started, my antifreeze never went down, I think its supposed to smoke a little bit , like condensation or something. Usually only one head gasket would go bad first and both sides are smoking the same amount. And the motor was recently rebuilt.
Old Aug 4, 2003 | 11:04 AM
Pro
Guest
Posts: n/a
Iv posted this like tons of times, but see if this looks like your car:
ftp://68.1.231.79/smoke.avi
This is what mine does, although its not as bad now that I put in some treatment (which made my oil pressure SKY ROCKET...)
Scoggin Dickey is working on my car right now, trying to figure out why the car runs rich (and gives a very nasty fuel smell causing migranes).
Old Aug 4, 2003 | 11:36 AM
Don't forget most exhaust has a Y-pipe so all the exhaust is then running through one pipe into the muffler which THEN goes into two. So even if it was one head gasket it would be coming out of both pipes. That is, of course, unless you have true duals...
Old Aug 4, 2003 | 11:39 AM
Pro
Guest
Posts: n/a
Which I would love to have. Not sure if there is enough room.
Old Aug 4, 2003 | 12:01 PM
joey_Z's Avatar
Before I bought my car from my uncle it would do the same thing. every time they would start the car alot of white some would come out but just when it strated. I'm not sure but I think it was the valve seals. they sent the heads to a machine shop and fixed them. I think they said it was becuase they overheated the car and they burned. now that I have the car it never smoked again.
Old Aug 4, 2003 | 12:03 PM
Valve seals would be blue smoke.
Old Aug 4, 2003 | 12:06 PM
joey_Z's Avatar
I just saw your video and my car used to do the same thing when it would start. Has your car ever over heated.
Old Aug 4, 2003 | 02:17 PM
shwine617's Avatar
true about the Y-pipe, I should have been smater than that....no never overheated, the motor was rebuilt,it doesn't smell like oil or antifreeze
Old Aug 4, 2003 | 02:23 PM
How long has it been going on? How has the weather been? If it's been humid/misty/rainy maybe it's just condensing in the pipes? I'm clueless....
Old Aug 4, 2003 | 02:27 PM
shwine617's Avatar
its been raining alot, i think its just normal condensation, I know its not a head gasket, I've had to change them before and I know its not oil, my auto teacher said once its normal to have a little water in the exhaust.
