LT1 Cam question
Old Jul 26, 2003 | 12:47 PM
thezisking's Avatar
LT1 Cam question
Would a cam from an LT1 Corvette be too much for my 86 camaro? The motor is stock. Thanks!
Old Jul 26, 2003 | 02:33 PM
hmccoy's Avatar
LT1 Cam question
the LT1 is a roller cam that requires a cam retainer in the front and and uses a distributor drive in the front and your engine uses a rear drive distributor. but if it would fit it would run great.
Henry
Old Jul 26, 2003 | 05:38 PM
mrr23's Avatar
it has the distributor gear drive on the cam. but your 86 is a non-roller block. you would need to spend about $600 to convert it so you can use it.
Old Jul 26, 2003 | 06:44 PM
12Second3rdgen's Avatar
The motor would need to come out of the car too, it would need to be drilled and tapped for the lifter retainers. www.sdpc2000.com has a cheap kit with roller lifters, the lifter retainer and all the bolts and what not for around $200.
Old Jul 26, 2003 | 06:45 PM
mrr23's Avatar
no it wouldn't need to come out. he could get retrofit roller lifters and a cam button.
Old Jul 26, 2003 | 06:48 PM
I'm probably mistaking, but I thought that retrofit hyd. roller lifters didnt work with OEM style camshafts.
Old Jul 26, 2003 | 06:50 PM
mrr23's Avatar
never heard of it. but you could be right. the only difference is how they are kept from turning. but i will say it is an expensive way to do this. you could be better and cheaper off just getting a hydraulic flat tappet cam and lifter kit. usually around $160
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
