My 305 TBI Needs Power!
Old Jul 23, 2003 | 05:45 PM
Decap92RS's Avatar
I am 18 years old, still working for minimum wage, so Im low on funds. I have a 1992 RS with the 305 TBI in it. It runs strong and all, but im sick of pulling up on V6 Mustangs that can take me. I just bought an LT1 cam, and with it I am putting in LT4 valve springs, a chip(gotta figure this out too), and the Edlebrock Performer TBI intake. For me, this is a big thing, but I was wondering, what other mods can i do to my car thatll make me go faster, but won't leave me in serious debt.
Old Jul 23, 2003 | 07:32 PM
92_RS_305's Avatar
Get either the stock air intake system off a '82-'84 305 carb motor, which would be the dual snorkel or get an Open Element. Both of these are much better than stock and get you better airflow. Also, you need to get rid of the stock cylinder heads.....either go with Vortec heads or World S/R Torquer 305 heads. Then you may want to get some headers and 3" catback. Also, a set of gears will help you out a lot. I'm currently saving to get a posi-lock to make my rear-end positive traction and get a set of 3.73s.
Hope this helps some.
Old Jul 23, 2003 | 07:53 PM
lordmetalz28's Avatar
yo bro get your self a set of jet power pulleys they where dyoed at 17hp and 13rwtq if you dont believe me check out the july issue of gm high tech its in bold print dynoed also buy some used k and n,s off ebay buy a ram air kit from mycamarozl1@aol.com
142$ for pulleys
30$ for used k and n,s
50$ for ram air
thats like 25 extra horse for 200 bucks no lie read the magazine
and also after that get yourself a 350$ flowmaster catback hollow out your cat as well if you can get away with emission,s
10-15 hp
also cahnge the oil and tune up the bitch, also a good idea to check your tps
Old Jul 23, 2003 | 07:55 PM
also i dont know what kinda work you do but get your self an apprentice job with and air conditiong contractor, very in demand this season youll start at 10-12 bucks but your over time with be tremendous and you can probably bbring home 500 bucks on a good week till you get more adavaced
Old Jul 23, 2003 | 09:48 PM
slayer6x6's Avatar
you will not get 17 HP from pulleys
Old Jul 23, 2003 | 09:56 PM
slayer im hooking up my web cam cause i dont have a scanner and im going to show you the dyno results no pun intended but on a 87 305 firebird tpi it made 17hp and 13rwtq this is from jet power pulleys its true i didnt believe it myself but its written clear as day mail me for a picture
Old Jul 23, 2003 | 10:05 PM
12Second3rdgen's Avatar
They used an LB9 car in the article, not an L03 car. The 87 firebird had better induction, was rated between 20 and 45 more horsepower and is an all around better platform to mod to begin with. Chevy high performance swapped pulleys on a newer TBI 350 chevy truck and the results were pitiful.
Your next best mod for your money is gears. A local guy at my track runs a 91 RS and runs 15's with 3.73's, posi and S/R torquer heads.
Old Jul 23, 2003 | 10:14 PM
Greed4Speed's Avatar
You can get a cat back system etc, but a cheaper route would be to get a cut out and put it before your cat. That is if you don't mind the noise and can get by w/out the law messing with ya. Or you could get a used 3" cat back off ebay or from someone. Check out your local F-body type club. Personally I don't think there is a huge difference from a pressure bent system and a mandrel system. Maybe 5 hp difference, and you can get a complete system installed for less than a mandrel system that you still have to get installed.
Also the advice on the Vortec heads I don't think would work on the 305. Their 64CC chambers will kill your compression ratio. Stock 305 heads are 58CC. The torquer S/R heads for a 305 is ~$500 or so.
For cheap grunt...gears. They make a huge difference in any engine, but make your speedo off and decrease fuel milage some. Get gears that'll put your car running in the power band of whatever cam you have. Later on get a converter that'll match your cam profile for more power on the launch.
Also like has been said. Free up airflow in and out of your engine. Also, make sure you have good traction. If you're spinning off the line thats wasted torque that could be putting you in front of the competition. DON'T GET TIRES BECAUSE THEY ARE CHEAP!!! Get some tires that'll grab. Look into some rear suspension mods too.
I also don't know about the LT1 cam. Any of you 305 guys know??? I know they do well in the 350 but not too sure about the 305. Its easy to overcam those engines.
Even with mods, there will be 6 cyl cars that'll pull ya. Not to mention those factory turbo charged 4 cyls. Watch out for an SRT-4 or WSX. Just look at it reallisticly. You have a 16 sec car stock, with the stuff you have and cheap mods you'll get in the 15's maybe high 14's. V6 Stangs, Grand Prix GT's, Grand Am GT's, 3.8L F-bodies all run in the low to high 15s stock.
Old Jul 23, 2003 | 10:47 PM
slayer6x6's Avatar
I saw the article, and from first hand experience I can tell you that pulleys will not give you 17 HP.
Old Jul 23, 2003 | 10:52 PM
an L03 is a 92 modle correct lb9 would be our tpi,s im buying these pulleys friday so after they get mailed and installed ill be telling you what gains i get hey slayer how did you install them where they hard to install
Old Jul 23, 2003 | 11:29 PM
Beast5spdGTA's Avatar
Headers and 3" cat will give you the most HP gain. The stock induction (modified) and stock TBI will provide enough airflow well into the 14s. Check my car in sig.
Ran 14.7s @ 93 mph on the stock cam and 14.48 @ 96.28 mph with a L98 cam. Swapping the cam with REQUIRE a custom chip to run well and make power so keep that in mind before you spend 15 hrs or so swapping that cam.
Here's a link to my dyno graphs comparing the stock cam vs. L98 cam. dyno graph
Some timeslips reflection mods and improvements.timeslips
Old Jul 24, 2003 | 02:59 AM
Decap92RS's Avatar
What about the Edelbrock Performer TBI intake?
Old Jul 24, 2003 | 04:02 AM
IZ28's Avatar
If you really like the car and intend on keeping it, I'd save up for a nice 350.
Old Jul 24, 2003 | 09:32 AM
Lets put it this way, my stock 350HO crate engine in front of a turbo 350 with a 3000 stall, 3.73's and posi on radial T/A's with a demon 650 carb and a performer intake for vortecs (not even an rpm) went 12.88@105.X and 12.93 @ 106.1mph.
A guy with my same crate motor with the same gearing underneath a 670cfm aftermarket TBI unit ran 13.9 @100 mph. Obviously he may have some tuning issues to deal with, but TBI has never been big on my list for 1/4 mile stuff.
Old Jul 24, 2003 | 11:32 AM
I think most people pick up a used carb intake and use an adapter b/c it's a lot cheaper, then they also have a carb intake for when they give up on custom tuning and switch to a carb.
