Hi-beams
Old Jul 24, 2003 | 10:47 PM
Loowee42's Avatar
Hi-beams
Hey everybody,
Took apart my steering column to fix my ignition and put it back together only to find later that my hi-beams aren't working. I pull back the lever to 'click' them on and the lever won't click at all. What did i do wrong with the reassembly? thanks for any info.
Old Jul 25, 2003 | 12:12 AM
Slow91z's Avatar
Uh......yes
Old Jul 25, 2003 | 09:59 AM
Black6SpdTA's Avatar
Mine didn't work before either. I took apart the steering column, rebuilt it and it worked. I forget exactly what I did, I'll take a look when I go out there today.
-Rippin
Old Jul 25, 2003 | 12:44 PM
TheGreatJ's Avatar
The dimmer switch is actually at the bottom of the column. It's a little white plastic can with a rod going into the top of it (rod comes from the lever and actuates the switch.) You may not have the rod seated correctly.
Old Jul 27, 2003 | 11:00 PM
Loowee42's Avatar
thanks guys,
I'll take a look and see if i can figure it out this week. "uh....yes" that didn't really help, but thanks for the... 'reply'?
LTR450HQ.com
Dec 2, 2009 05:07 AM
SVThuh
May 9, 2007 07:19 PM
bonecrusher
Jun 23, 2005 11:26 PM
