Location of the buzzer?
Old Jul 26, 2003 | 08:33 PM
Pro
Guest
Posts: n/a
I have this part I found in the car... looks like a buzzer, part number 14034321. Says "Lectron - Rochester, MI" on it. I noticed that i dont have a door chime at all. Assuming that this part needs to be replaced (maybe the reason it was disconnected?), where should a new one be plugged in? I probably could have found where it goes if it had an existing one already installed, but I cant find anything like it. Any ideas where it goes? Thanks
Old Jul 26, 2003 | 11:54 PM
cwalsh
Guest
Posts: n/a
I kow in my '89 it goes directly behind my ALDL connector. there is a small second fuse block under there that you have to squeeze two tabs together to get it to pull down. It should go in there. HTH
IndyZman
Oct 22, 2015 02:17 PM
RubyRedIrocZ
Sep 10, 2015 01:48 PM
RobFlag
Aug 29, 2015 11:40 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
