twin air filter setup, cut out the bottom of airbox ??
Hi
I have a 1990 camaro and somebody told me to cut out the bottom of the airbox and make a direct connection to the outside of the car for some added horsepower. I need to know from people with experience. Will this let water and heavy dirt through? Will it hurt the car at all?
thanks!!!
thanks!!!
heres how to do the Ram air system.
http://www.thirdgen.org/newdesign/tech/ramair.shtml
the ram air coupled with k and ns and an air foil bring the engine to life the ram air alone on a 305 dynoed at 12hp and thats just with a fan in front of it imagine what it can do at 90mph and when you find out let me know my upshift sleeve is shot so i keep upshifting at highspeeds i cant enjoy it k and n,s disperse water so water isnt a problem and your air filter takes all the dirt no worries
Its not the ramming of the air making the HP increase, its the cooler air coming in...you have to be going alot faster than what most 3rd gens can do (closer to 200mph) for any affect of RAM AIR! Its simple to see, the air being sucked in by the downward stoke of the piston is greater what you can drive at, so RamAir is just a cold air intake. Is it worth do gut your airbox...yes. Are you ramming air in...no.
well I see you resort to name calling...congrats...just a little info on physics...you cant force slower air into a faster stream and make more of it. The air coming into a cylinder is a hell of alot faster than 55 MPH... you say what you think but facts are facts...Like I said, its not the ramming its the cooler air...
read on and learn
You must be one of these guys that thinks putting a "electric turbo" in thier intake makes power.
read on and learn
and also thats the dumbest thing i ever heard ill race your stock camaro agianst any of the same with ram air for 25,000 and titles thats how confident i am and im backed by dyno sheets go buy a honda and get off this page
Not your buddy, lets get that clear.
Now can you show your mystical proof??? Can you link me to this so called dyno proof? I showed already that its a myth, you cant comprehend it so if you care to show me your proof I can probably break it down to your level and explain what you think is wrong.
read on and learn
read on and learn
Am i way off base with this one? Please explain how i am wrong. Also by your logic wouldnt a cold air intake and a ram air intake net the same gains??? Does anyone have a comparison test between the two?
I am sorry Lordmetal, Aron is right.
While I do not dout your gains, and I am about to do this mod ( maybe tomorrow ) There is no ram air effect.
The advantage is that the air is colder, colder air is dense and thus there is more O2 per ( lets say ) cubic inch. This is why you see gains.
We can do a home exsperiment to see why then there are gains ( as you say 50mph ) when it is warm out. First put your hand up to your mouth like you are about to yawn. Open your mouth wide and breath, as if you are fogging a mirror, the air is warm right? Now pucker your lips and blow as if threw a straw, cooler now hugh?
If you dont buy this then you should by my physics book, slightly used I will let it go cheap.
