air foil install
Old Jul 28, 2003 | 09:40 PM
lordmetalz28's Avatar
air foil install
got a question here my air foil should i be worried about some of my gasket falling into my tb im going to change the gasket anyway so when i peel it off do you think itll stick the top or the throttle body if so how do i do it without removing my throttle body
Old Jul 28, 2003 | 10:15 PM
slayer6x6's Avatar
You dont need to remove the throttle body to install an airfoil, its placed on the front. The only tool you need is an 8mm wrench. If you are going to change the gasket, then you will need to scrape the gasket off (a razor works best).
oh and by the way punctuation and capitalization help because when someone reads your post it is easier for them to understand otherwiseitbecomesabigmessofwordslikethis
94z28jbw
Sep 8, 2002 03:22 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
BM93Z
Aug 22, 2002 02:45 PM
turbo_Z
Aug 19, 2002 10:50 PM
