View Full Version : LS1 Based Engine Tech
- SLP LoudMouth owners
- hotcam or old man cam
- New product - Meziere "street" electric water pump
- "certified???"
- SLP MAF dyno numbers
- Estimate this power combinations
- 8# ATI reliable on LS1 Engine?
- power antena
- Which would you prefer? MAF question...
- Is this right????
- Slp?????????????
- A/C Help
- wheel backspacing ? for a friend
- Header install help needed!!!
- Borla vs. Stock
- all guys with tach or shiftlight inside please
- Electrical Question
- Ok here's the combo, guess the power...
- Best drag radials? Are nitto and bfg the only ones?
- TPS modification
- what stall converter and a couple of other questions
- Radial Pull???
- Tranny Noise
- need some help with deciding?
- LS1 Durability
- Trans Am
- Has anyone ripped some emissions out?
- paper filter or k & n
- How hard is it to put in a B&M shift kit on the 4L60E?
- where does your clutch start engaging?
- AC problem help please!!!!
- Stock Dyno Run
- Sudden loss of power
- Quick Question
- Tremac tranny is 2000 TA?? Stock or no?
- New numbers :)
- How to reset PCM after removing cats?
- GM's 5 yr. Battery
- Help!!!!!!what Do I Look For!!!!!
- Good dyno #s
- Good future mods?
- CUTout with muffler ?
- Another air box question?
- Just ordered up a Shaner S2 T.B!!!
- Stall Converters
- My other problem- Clutch slipping
- Electrical glitches
- WS6 Air box question
- Hey I passed a sniffer test with no cats!
- Hit curb, huge positive camber
- LS1's ignition...
- Which muffler will give me a louder sound than a magnaflow?
- FTRA or SSRA ? Which is better? any others?
- What is a cut out on an exhaust?
- value depreciate after coler change?
- 11.30s is the LS1 bolt on record??
- Just some LSx questions...
- ? About the 01 Bcm and its Duties
- SLP Cam Package
- SS spoiler
- Speed INC ported T.B anybody???
- Wheels
- Is there anyone around that can restall torque converters?
- Whats louder? Cut out, Loudmoth, or GGMG?
- Please explain long tubes and cats?
- Which muffler to get?
- Avarage RWHP with a cam and bolt-ons?
- i have a free mod question help me out!!!
- ZR1's Rear 11's vs 9.5
- system lean and engine codes
- 135000 to many for the ls1
- write-up w/ pics on headlight and foglight mods
- Which Exhaust
- New owner
- conservative mods
- Still fighting the Borla rattle !!
- Differences b/t '01 Z-28's???
- has anyone done this with their SLP LM?
- SLP Lid
- Fastest Streetable LS1s?
- all year 1LE spring rates vs 99+ SS rates
- Is Blow Head Gaskets Common
- Induction
- Service Vehicle light
- Help car just went from very fast to very slow
- 2000 SS, 4.10 gears and eating oil
- cold air induction
- Titanium exhaust system for LS 1 ?!!
- Headers, cat back exhaust...and the air pump...
- Where to find rear ends for sale?
- clunk in drivetrain, rear?
- '99 Turning over but not starting
- Muffling cam and headers
- Hooker Y on SLP LT's
- rockford IL
- more cut out questions?
- check this out
- mods to air lid
- tire size
- hard shift
- BMR Lowering Spring Install Walkthrough
- Tires
- LS6 intake
- FAST LSX intake
- LS1 LM Dyno Video
- SLP Air Lid with " Blemish "
- Need help with a lugging problem.
- need a fast easy answer
- Where to put a cutout
- 1st Time dyno numbers
- ls1 bottom end too brittle?
- Warranty Gold update... 6 weeks later
- Anyone else been told their powertrain warranty is void after simple bolt on mods?
- Part # for K&N for LS1?
- How hot is an LS1 supposed to get?
- supercharger or heads + cam
- Pictures of interior needed
- egr
- magnaflow+no cats
- What is causing my knock??
- 1998 camaroZ28
- How much power am I making?
- broken crossmember
- Bigger Engine into my Z28?
- FireHawk vs WS6?
- Need help on buying an LS1 T/A
- Should I be worried about an 01 with 83K miles?
- Which Shifter for a 99 m6?
- What to do for induction???
- CC 218/224 Users, Opinions Please?
- Torque converter and shift kit???
- Paging cmotorsports.com
- whats the fuel pressure?
- Anyone have T-Tops That Leak?
- Z06 clutch
- SS Hood
- Need help finding a Ypipe
- Yank Sportsman Transmission
- I woudl like to buy a loudmouth
- LS1 Swap in 95 3.4L Firebird.... Input??
- Mounts?
- Rear-end hopping
- 4:10 gears and daily drivers
- Thermostat
- operating temp after 160* stat
- Corvette FRC's
- BG ram air???
- I LOVE this CAR!!!!
- Comp Chip for 98 LS1 M6
- Ground effects?
- Will an energy trans mount and a pro 5.0 shifter void my warranty?
- Anyone running the Agostino Racing Engines (ARE) Cam/head/intake package?
- How do I get rid of my ASR?
- clutch
- Finally joined you guys, newbie questions inside
- Had my car dynoed today...
- removed front sway bar?
- changed trans filter today and trans wont shift
- getting my new tranny back, teach me.....
- Clutch wont copme out all the way?? WHAT THe HELL?
- All you guys with loud cars inside...
- Anyone with a remote start, please help me!!
- 1998+ Trans-Am Headlight Conv. Kit
- ls1 heads flow as well as 4 valve cobra heads
- Cluth Adjustment
- Hooker header question
- Slp Loudmouth
- Who has a good sleeper cam?
- Dyno sheet anyone?
- Transmission knocking?
- LS1 Front Brakes: Wear Indicator Inboard or Outboard?
- Headers installed insane loud !
- ls1 alternator
- Ground Control Coilver Spring Rate
- Best Ram Air hood?
- Where can I get this hood? Cheapest price?
- Power Programmer question (slowin me down??)
- Need help quick question
- SLP air temp module
- Cutout Question???
- Free Ram Air Mod!?
- Ever so slight stumble off idle...where to start looking?
- An update from my cheap tires
- Help me spend $1000
- Exhaust System Advice
- New 99 TA!
- 97-99 LS1's doing 400rwhp?
- Where to find?
- Which Cam to get for SS?
- High HP Guys, what tires for street?
- Which subframe?
- New Dyno with H/C's
- ls1 free mods
- Quick Question about LS1 Motorsports Lid.
- ls6 intake on my 98 z28
- Guys please help! What did my Ls1 do??
- Engine Removal
- Lowering Stock SS Springs??...+
- Rear End Question
- A question on the SES light.
- What size electric Cutout?
- An iron block maybe?
- which to get
- Miles on your LS1's....
- maf ends??
- Finally got the cutout in!
- TRUTH Behind the power-shift?
- missed shift 3-4 ????
- 2-3 hard shift
- Help needed - clunking sound
- alternator replacement
- Can codes be checked without a scanner on a 99?
- Help diagnose problem...
- Can someone please run a carfax for me?
- Will 18's fit up front
- LS1 Hooker LT's and Cutout clip...what u think?
- what to do for 12's
- how much should welded SFC install cost?
- What Mods should be next?
- z28 into SS or SS
- heres my setup....
- Son of a !! Help
- whisper lid+ftra vs. tsp lid +ftra
- wheel and tire combo
- Pics of MAC headers w/Y pipe installed please....
- cheap tire problem ?
- Someone must know the answer to this easy question
- SLP CAI worth anything?
- what else to do?
- Anybody got pics of where they put their cutout?
- NXExpress lit on stock LS1
- Size of, or where to buy, banjo bolts for front calipers?
- Dynomax Bullet Diagram
- just got back from dyno...
- Need help w/ cutout info ASAP!!
- Are Double Diamond SFC's worth it?
- HELP! My M6 leaks!!
- what ujoint for moser 1350 yoke?
- header gaskets
- 99 TA-Codes P172 & P172=running rich w/Macs and O2 sims
- f/s 3600 convertor for T400
- Website purchases
- How to change gauge bulbs
- AC Not Working... NEED HELP!!!
- superchip's microtuner... BS?
- Exhaust
- fuel pump
- T-Tops
- Help me Decide!
- quick window question
