getting my new tranny back, teach me.....
Old Jul 20, 2003 | 03:37 PM
Michael Ozorowsky's Avatar
Ok. I know a bit about cars, but I want this post to be more of a refresher. SO here it goes....
I'm getting my newly built 4L60E back, and want to know the do's and don'ts.
Change the fluid/filter every 15k miles, right?
Is it ok to manually shift it?
Tell me everything you can think of that I do/do not want to do. Is power brakeing bad? (Holding brake hard, and pushing on gas until tires spin).
Please tell me any info. you can. Thanks.
Old Jul 20, 2003 | 04:14 PM
ZIPPERR's Avatar
Re: getting my new tranny back, teach me.....
Yes.
No! But who doesn't?
Yes! It's bad for your drivetrain and trans.
Old Jul 20, 2003 | 08:08 PM
Drew778/94Z's Avatar
Put a drain plug in and change the fluild every 7K and fluild and filter every 15K
No!!!
You should be fine.
Please tell me any info. you can. Thanks. [/B][/QUOTE]
Add a trans cooler if you don't already have one.
Hope this helps.
Old Jul 20, 2003 | 08:48 PM
already have a transmission cooler and B&M Deep tranny pan with drain plug.
Also, I am having the shop put in a transgo shift kit, and I am running a Yank PY3600E verter. I know my rear will be the next to go. I just don't want my tranny to go again. I am gettin ga procharger with 8# of boost for my next mod. So that is why I am having my tranny built to hopefully (Supposedly) handle that much power.
Old Jul 21, 2003 | 01:32 PM
is revving the car in park bad for the transmission?
how about throwing it in neutral and giving someone a rev?
Old Jul 21, 2003 | 04:24 PM
chevy qc's Avatar
fluid and filter i'd recomend about every 10-15k. manually shifting is better left to someone with a manual valve body as it's not needed with something you can program your shifts with. only time i recomend shifting it yourself when doing a burnout. i'd try to hold it in first unless it's spinning too hard as it's pretty hard on the 4L60E's to make the 1-2 shift under that much load due to the wide gear ratio split.
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
Snoman73
Nov 17, 2014 07:22 PM
