A question on the SES light.
What do you mean? There's plenty of sensors behind the cat that can trigger the SES light.
Also, the fuel system is pressurized. If you leave the cap off, it fails to pressurize the system and triggers the light. I think something to do with emissions and fumes leaking from the car...
What are you referring to? Emissions, or anything in general?
Emissions would be the gas cap because the sealed and pressurized system is designed not to leak out fuel fumes and keep emissions from the car in check.
Anything else would be like rear ABS sensors, TCS sensors if so equipped, etc.
dluna333
15
Mar 13, 2015 12:30 PM
96z
Aug 2, 2002 09:00 PM
