Need help w/ cutout info ASAP!!
I set up an appointment w/ a local speed shop for 1:30 so I need info fast. I'm getting a flowtech cutout put on and eventually I would like to wire the McCords Power Plate to it. The people at the shop are saying you cant do it with the Flowtech. What part # is the one that can be used with the MPP2? Also, Im assuming I need the 3" cutout. Thanks.
all you need is a three inch opening with a three hole flange. If you cutout has that, any electric cutout will mount to it (As long as you have space for the motor. I mounted mine "Zed" style and there is only one way my electric cutout will fit, and it is even close)
The MPP2 seems to be the most used from what Ive researched. I know they had problems with the 1st one but I didnt read anything bad about the new one yet. Does anyone know if flowtech possibly produces more than one type? Maybe this place has the wrong one??
Henson071
Sep 21, 2015 04:31 PM
tdigger9899
Sep 7, 2015 10:56 AM
