An iron block maybe?
Old Jul 17, 2003 | 11:56 AM
KwikistZ's Avatar
Does anyone know if they make iron blocks for the LSx motors? I was planning on building an LSx motor, but don't like the idea of an aluminum block. Anybody at aLL??
Old Jul 17, 2003 | 12:05 PM
Bone Maro's Avatar
The 5.3 and 6.0 blocks out of the newer full-sized GM trucks and SUVs are LS1s, but all iron. All the usual parts from the LS1 swap into them, and so forth. That's how you hear of guys with LS1s running 427 strokers, they're using the iron blocks.
I believe the engine codes are LQ4 and LQ9, respectively. But don't hold me to that
Old Jul 17, 2003 | 02:24 PM
dis3as3d's Avatar
Not true, some shops use the C5R aluminum block for the large displacement LS1's.
Old Jul 17, 2003 | 02:49 PM
My84Z's Avatar
does it make a difference wich block you use?
Bone Maro's Avatar
Well, that's a long-shot exception. The C5-R block is ridiculously priced and most average hot-rodders can't afford one, let alone the work that it needs done.
Also remember, the C5-R block may be a direct bolt-on, but the parts aren't. The heads are different degreed than a regular LS1 and swapping out most topside bolt-ons, including heads, won't work.
Old Jul 17, 2003 | 07:23 PM
KwikistZ's Avatar
Thanks guys! Also, how big, cubes wise, is a 6.0? Maybe I'll use that instead of the 355 I planned on. Actually, that 427 stroker sounds fun
Late!
Old Jul 18, 2003 | 04:03 PM
pg318's Avatar
Late!
6 cubic decimeters, actually 5967 cubic centimeters, or for those of you that think in old money, 364 cubic inches.
Old Jul 18, 2003 | 04:51 PM
Beast96Z's Avatar
MTI makes an aluminum blocked 427. It comes with a 2 year warrany also. They also have 427 iron blocks.
Old Jul 19, 2003 | 01:37 AM
AL SS590 M6's Avatar
Moderator
There's a company out there now that offers a re-sleeve for aluminum LS1s that want to go big cube. Over 400 cu. in. available.
Old Jul 19, 2003 | 06:51 AM
Bone Maro's Avatar
This is for the 99+ blocks, correct? My 98 has the thinner cylinder walls, and from what I understand, can only be sleeved so much. Limiting my displacement options...
Old Jul 19, 2003 | 07:05 AM
Moderator
No they take the factory sleeves right out and slap these BIG ones into your block.
I haven't checked into it extensively but I'd assume that the heads clamp the new sleeves in place like in a big diesel tractor or truck motor.
It ain't cheap but it's not C5R money either.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
