97-99 LS1's doing 400rwhp?
Old Jul 18, 2003 | 09:10 AM
GigaMp3z's Avatar
Just incase you guys jump down my throat (wait a min..that would never happen on ls1.com ) there was a 97 ls1 and it was put in a c5 corvette. I see alot of cam only ls1's (2000+) models pushing 400rwhp with boltons including and a cam. Have any of you seen 97-99's doing 400rwhp or real close to it with all the boltons (including ls6 intake) and a cam? The head castings in 2000 (or was it 2001?) changed to a new part #. Although said to be the same, do you think thats where the added power
comes from?
thanks,
Corey
Old Jul 18, 2003 | 01:45 PM
ChrisLS1Bird's Avatar
What added power?
The only added power came in '01 with the addition of the LS6 manifold. '98s and '99s run like hell. You're reaching for something that's not there.
Look on ls1tech.com for some ~400 rwhp examples.
Old Jul 18, 2003 | 02:54 PM
JaysZ's Avatar
In addition to the LS6 intake, I think the '01-'02 LS1s received other minor enhancements that may have contributed to increased power- larger fuel injectors, slightly better flowing exhaust manifolds, the smaller truck cam (which may actually deliver better low end torque), and maybe some PCM re-tuning. Overall, the increase in power may be a little more than just the advertised 5 horses.
Old Jul 18, 2003 | 04:26 PM
CamaroBoy96Z28's Avatar
Re: 97-99 LS1's doing 400rwhp?
All 97 Vettes came with the LS1.
Anyway I agree with the other guys. Even with the addition of the LS6 the average stock output was 355-365rwhp. Its going to take all the boltons or maybe a little more to get 400rwhp.
I also agree with JaysZ. GM never rated the LS1 correctly and I'm sure there is definitely more than the advertised 5hp difference. Weiand advertises 12hp with the LS6 manifold so theres at least 12 right there.
Old Jul 18, 2003 | 05:58 PM
Alucard's Avatar
Originally posted by JaysZ
Ilarger fuel injectors
Actually, '97-'98 Had the largest injectors at 28lbs.
Old Jul 18, 2003 | 06:18 PM
Geeterman's Avatar
I'm pretty sure the 01 and 02 injectors are just as large as the 98 injectors if not larger. The cam in the 01s and 02s does offer more low end torque but at the same time sacrifices high end torque.....
Old Jul 18, 2003 | 09:04 PM
GigaMp3z's Avatar
Maybe you guys don't understand what I was asking..I am not talking about stock power #'s. Honestly, how many cam only w/ bolton 97-99's have you seen close to the 400rwhp mark? I don't know of any. I have seen quite a few 2000+ models tho. Let me know what you guys think.
-Corey
Old Jul 18, 2003 | 09:18 PM
Cbra Kilr's Avatar
Incorrect , sir, 98's had the 28.7 LB/hr.
Old Jul 18, 2003 | 10:33 PM
ULTIMTEORANGESS's Avatar
i thought 02s had the largest injectors?
i thought there were full bolt on ls1s with cams dynoing at 400rwhp on stock heads.ill bet theyre m6s.
Old Jul 19, 2003 | 10:15 AM
JaysZ's Avatar
Not that it makes a big difference, but I believe the '01-'02s have 28.8 injectors- bigger by a hair on a gnat's ***.
Old Jul 19, 2003 | 12:16 PM
Greed4Speed's Avatar
Correct me if I'm wrong, but don't most LS1's run about 300-315 RWHP stock. I know they're under rated at 320 - 345 hp (if it came w/all the SLP bolt-ons) from the factory, but that is at the flywheel, not rear wheel. Wouldn't 400 hp at the rear wheel would require more than just bolt-ons? Unless your counting superchargers or N20 as a bolt on. I don't consider an LS6 intake change for an older LS1 a bolt on either.
Having a smaller cam in the newer LS1's (as with any engine) would actually decrease the peak HP. Smaller cams generate torque at lower RPM at the sacrifice of higher HP ratings. Thats why I couldn't care less about HP ratings. Give me torque numbers!!!
With all that said. I really can't say that '01-'02 LS1s are really faster. I've ran some stock ones with my stock '00 and we were neck and neck. I pretty much boiled down to who was shifting better or who got the better launch.
Old Jul 19, 2003 | 06:12 PM
thechef's Avatar
with all the boltons and a aggressive cam you can get a 98-02 ls1 car in the 390-400rwhp
there are several cam choices out there that can do it with the right headers and bolt ons and a good dyno tune
Old Jul 20, 2003 | 01:35 PM
The point is that there really isn't a difference when the engines are modded. Get it?
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
