T-Tops
T-Tops
I have lost 3 driver side tops off my car while driving. It has also happened at the drag strip. Normally it occurs when I shift from 1st to 2nd, however i have lost one while running aroung 160. I have a 99 Z28 with tubular frt A-arms, sub-frame connectors, G2 lower control arms, panhard rod, solid motor and tranny mounts, spohn torque arm, and 407 hp and 396 ft lbs. of torque. I haven't even put the bottle or a blower on my car yet. I have the supercharger in the box but I spend more money on tops that i do in a car payment. Before i install it I want to make sure i'm not gonna loose any more tops. Cause at 160+ when a t-top flys out you tend to get a little scared.
I only loose the driver side top not the passenger. I even keep'em locked. What is the best way to halp stregnthen the body without caging it? I love the sleeper look and don't want big bars that people can see!!
Does anyone know of a website or a shop that might sell any kind of body stiffing package?
PLEASE HELP ME!!!!
PLEASE HELP ME!!!!
For a t-top to just "magically" fly away, the way I see it, defies physics. Either there is something wrong with your locking mechanism (the holes on the care the locks stick into) or you are not properly putting the t-top in. But losing 3 must really suck though. Good luck finding the problem.
Something to check...
Hopefully I'm not beating you with the obvous stick here, but check this...
On my car the back T-top mount bolts on the drivers side had worked there way loose, and started to slide backwards. What this did was make the amount the rod engaged into this back mount less. I've never lost one, but I could sure see it happening with a problem like this. Try adjusting the two mounts on that side as close to each other as you can. Hope it helps. I now have almost 1/2 inch of engagement, and I'm thinking thats more then enough to allow for some chassis flex.
David
David
i also had a buddy of mine have his ttop just all of a sudden rip out and fly away...he was doing about 75mph. that video was cool looked like a pilot about to eject and blowing the hatch..sweeeeeeeet
T-tops
Thanks guys I'm serious i lose them alot. I did measure the gap and the gap is 7/16 in the rear and 1/4 in the front. the passenger side is like an 1/8 on the frt and back. I took my car to Speed Works in texas and one of the guys said that. I am going to have to cage it but since the gap is so big that i might want to take it to a body shop and have it straightened.
So YOOO-HOOO!!!!! there's about a $1000 dollars the way i see it. Oh well.
It was in a fender bender but i didn't think it would have tweeked that bad.
And the tops are only $160 shipped to my house from www.fbodysalvage.com in PA.
Re: T-tops
As much as you want a sleeper look.. there is a bit of sacrifice that comes with it... I am thinking that perhaps you may want to see if there is a cage that isnt quite so noticeable...
take out the top, take of the rear trim peice, lossen the 2 bolts and slide the bracket the top slides into forward. this will correct the over flex and keep the top in the car, where it belongs. However this may affect the height of the top and may cause a slight drip, but at least it wont keep coming out.
