What is a cut out on an exhaust?
Old Jul 25, 2003 | 02:07 PM
Red Demon's Avatar
Question What is a cut out on an exhaust?
What is a cut out on an exhaust system? What's it's function or use? Price? Does it make your car louder?
Old Jul 25, 2003 | 02:09 PM
95GRNZ's Avatar
Exclamation
Welcome to the board!
Cutout issue has been discussed in great lenghts in the past few weeks. Please do a search and you'll find plenty of info.
EDIT: Try for example this thread found from page 3: http://web.camaross.com/forums/showt...readid=148888. That prety much tells you all you need to know about the cutout.
TS
Old Jul 25, 2003 | 03:09 PM
dis3as3d's Avatar
there is a search button too
Old Jul 25, 2003 | 09:15 PM
9TransAM4's Avatar
cut the guy some slack. he probably is new to the car and obviously new to the board. to answer your question, a cutout is basically a bypass of everything after the cat(s). so you will not have the exhaust going out the muffler. and yes your car will be alot louder. there really isint that much more you can do to make the car louder except headers. am i missing anything? when i have mine open, i often set off car alarms as i drive by. i believe it is supposed to give you around 10hp if u are interested. not bad in my opinion for 30 bucks. any exhaust shop could weld it in for you in about 20 minutes. hope this helps. welcome to the board
Nick
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Ringmaster72
Apr 2, 2015 08:32 PM
Jan 5, 2015 07:14 PM
