Just some LSx questions...
Old Jul 25, 2003 | 12:46 PM
KwikistZ's Avatar
I was thinking of building a 427 stroker LSx motor. Heh, wanted to go BIG! Anyways, I was looking at that sheetmetal intake on LS1Speed.com. Do you think that would work well with the 427? And also, where can I get an iron 427 block? Also, does anyone know where I can find a butt load of info on that Phase III ZL1 Camaro? Thanks!
Old Jul 25, 2003 | 01:00 PM
SSpdDmon's Avatar
It sounds like the C5-R block is what you're looking for. I know it's an aluminum block, but it's one hell of a base to start from. The only place I've seen recently that uses that block in a 427 package is SLP. But, based on all the things I've heard about SLP, I probably wouldn't go with much of their products. They don't seem to have the quality that you get with other aftermarket products for the same $$$. Good luck with your build.
ps - http://cgi.ebay.com/ebaymotors/ws/eB...tem=2424795410
Old Jul 25, 2003 | 01:17 PM
KwikistZ's Avatar
What would need to be done to a T-56 if it were to run behind my 427? How much would that cost to beef up, and what parts?
Old Jul 25, 2003 | 05:22 PM
Ken S's Avatar
The sponser MTI can answer all those questions from you.. You can stroke and punch out your ls1/6 block.. or You can go with an 6.0L iron block and puch that out.. or you can go with a C5R block..
If your really spendy, try to go with C5R heads on a C5R block, and have a custom intake manifold built for you... I'm not sure how they would work on a street car though, since they are made for LeMans racing, and compression starts out at 12:1 i think..
pepon214tx
Sep 20, 2015 04:48 PM
blkWidow
Apr 20, 2015 09:27 AM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
ryan2
Feb 21, 2003 01:03 PM
