SLP air temp module
Old Jul 19, 2003 | 05:17 AM
LetMeBurnU's Avatar
SLP air temp module
Is this worth getting? anyone installed one of these before?
Any thoughts on the slp air temperature module.
TIA
Old Jul 19, 2003 | 06:33 AM
ULTIMTEORANGESS's Avatar
useless ripoff.dont bother.this is a mod where you get what you pay for.
Old Jul 19, 2003 | 12:29 PM
SwingDriverZ28's Avatar
I dunno if it helps or not but I am running it, so are a couple of my friends.I installed it with a lid, filter and smooth bellow , so all 4 made a bid difference.
Even if I get 1-2 HP its worth it for $25.
Maybe someone dynoed before and after and will post.
Old Jul 19, 2003 | 01:08 PM
V6toZ28's Avatar
It advances the timing by fooling the PCM into thinking that the air temp is something it's not ... in some conditions you may get 1 or 2 hp .. in other conditions you may lose 1 or 2 hp or more ... particulary when it is hot out, with too much timing in hot conditions the car will ping, lose power and lose even more power if - hopefully - KR kicks in to protect your engine ...
Good Luck
Old Jul 19, 2003 | 10:22 PM
Greed4Speed's Avatar
Why pay $25 for it when you can run to Radio Shack and pick up a resistor for under a buck?
Old Jul 19, 2003 | 10:41 PM
also get SLPs shift improvement module while youre at it.
Old Jul 19, 2003 | 11:56 PM
LetMeBurnU's Avatar
slp shift improvement module?.........F*** that..
hahaha
Old Jul 20, 2003 | 05:30 PM
rotwiler's Avatar
When I first bought my 02 I bought the SLP module. Everytime I went to the track I actually lost time in the quarter when using it. So now it sits in my glove box. A couple weeks ago I made a run in over 85 degree weather and lost 4/10ths using the slp module.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
racecarz28
Mar 30, 2015 09:55 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
