- Opinions needed on car's value
- A/C blows, but it is hot
- question for pa/profab k-member owners
- Anyone Use The Auto Meter Speedo In Their 3rd Gen?
- time for Ensure?
- Tips on getting the motor back in the car?
- any1 replaced hatch stabilizer bars???
- valve covers???
- so i am shopping for a new convertible top now...
- Coolant Flushing...
- LT1 WS6 CAI fitment problems
- 95 Firebird flip up head light question
- Switching to illuminated heat/ac controls... what's involved?
- pics of coils mounted to radiator.. ??
- Car Cleaning Tip
- Rear hatch struts. BUSTED!!
- Installing a passenger door
- Help-Prospective SS Buyer
- Oil Pan Leak
- HELP-Its hot and no A/C
- Power Window electrical problem..need help please.
- Anyone know where to get drivers front fender?
- problems
- Power Steering System Flush
- Hooker Aerochamber Part #
- Attn: Shoebox Please Help
- Alternator going out?
- fender weight?
- Rear window! help...
- how to disable 95z alarm?
- My first car is a 1994 Z28. HELL YEAH!
- Coolant trouble...again
- Fixing firebird headlight motor?
- Hydra Rev by AFR
- Please help me!!
- G-Tech Pro Performance Meter / SS Model review
- question about the window motor mod..
- Gas Smell
- Where to get Power window motors?
- Who has swapped an LS1 into a LT1 car?
- im having 2 problems with my z28...
- Soon to be Z28'er!!!
- helicoil inserts??
- LZ1 Camaro
- Tach and volt meter have the shakes
- oil pressure sending unit
- Do Not Buy Pro-fab Products
- occasional no crank condition?
- Info needed on installing endlinks.
- New Z owner...did I get a decent deal?
- How do you make thefans kick on sooner..
- 93-96 Tail Light question
- A little A/C help needed.
- Fan ?
- 02 Convertible Rear Window Curtain
- Whats wrong with my A/C?
- MSD Blaster coil in 94 T/A
- Electric Cutout Switch
- Can I start the car with valvecovers off?
- What gauges for triple pod?
- premium or regular unleaded
- Switching over to Synthetic oil?
- new shifter knob problem
- Battery Questions: Deep Cycle?
- Pics of Ultra-Z ramair hood installation
- Bigger Throttle Bodies?
- Knight Rider
- Causes of poor gas mileage?
- Windshield Molding 97 Z28
- New wheels causing ABS and ASR to fail.
- UMI Performance?
- Can somebody clear this up for me?
- liscense plates
- 98-02 front end conversion
- Passenger side brake light out...shoebox???
- help removing rear speakers
- can I put the interrior of a 2000 camaro in a 96
- What is this thing, with the thing...
- Accuracy of HP gains in products?
- Will TA hatch struts fit Camaros?
- Should I change my oil???
- Harwood+Summit racing, three hoods sent back so far....
- park/neutral switch not working?
- Okay,What about Hatch Struts?
- Removing the Seat Belt
- Replacement window Motor
- Removing key/ignition cylinder
- Passed inspection
- how long does it take to remove a rear bumper cover?
- Gauge light fuse blowing
- Speedo just comes and Goes!
- roll bars
- steering column
- Finally got an exhaust (cutout) clip
- 2000 Z28/SS SLP, worth $18,000?
- Honda gu-ru's inside
- 99 camaro ss question
- Converting lap belt to three-point belt
- Looking to buy '01 SS....
- 3rd gen startup problem
- hi-jackers
- How rare is the F1 Camaro?
- question
- whould this d/s loope setup be ok
- Rear fin brake lens cover screws off?
- Turn signal and brake light broblems
- Ignition Lock Cylinder Jail Time Possible!!
- Build up the Z, save & buy ls1? other?
- A/C noise??
- no turn signals but hazards work.
- SES light
- Just changed plugs for the first time
- Trouble with K&N air intake.
- how can I tell if I have trac control????
- some engine advice please
- where can i buy this?
- Electric cutout..whats your fav. brand?
- this turbonator thingy
- Old gas still good?
- Replace Fender Left Front
- Improving 1/4 E.T.
- fire
- In your opinion what is the best spark plug?
- Corvette exhaust on a 02 Camaro?
- Adjust Miles?
- Replace O2 or get sims?
- Backing plates
- White smoke at startup,once in a while..
- 1995 Dash
- Shims with poly trans mount?
- '98 Ignition switch/VATS problem ?
- Improving speed & handling for race setup
- First steps of pulling engine(LT1)?
- What octane gas should i use
- How do you guys lift your car?
- head light ? need help asap
- Having a key made
- PASSING GAS or SMOG!!!
- I replaced the VSS... Still no Speedometer...
- Can I just change the bulb on T/A fog light?
- No traction on wet roads?
- Replaced VSS... Still no Speedo...
- Disable Automatic headlights??
- power antenna install?
- opti or fuel pump
- Flywheel or at the wheels hp?
- left blinker problems
- Who has taken out fuel pump in vert with trap door method?
- Who has exaust that exits in the center
- lt's-cutout-cat pic
- 98 t/a guage cluster in a 94?
- Does the 93 Z28 have passenger airbags?
- Removing gauge cluster for good any problems??
- VATS removal
- Catalytic Converter Problem
- Gauge lights not working
- Mac Headers
- To Those That Succesfully Moved Battery To Trunk???
- Vacuum-driven air controls not working
- Driver Side Door Pannel
- Mileage On 96 Camaro
- Powder Coat intake
- My blower motor is stuck on???
- Couple of Questions
- Help??
- Possible headlight relay problem?
- True duals
- failed emissions
- Rack and Pinion ?
- Any pics of notched panhard bar braces for true duals?
- Adjustable plates in the borla really do make a difference!
- Fuel Gauge is busted
- A Tired '96 Z28 to LS2? Swap/conversion
- Could this ne a bad PCM
- 1988 Firebird 208 fule pump help
- Headlights
- Am I suppose to have automatic headlights?
- Car won't start... (VATS? Clutch safety switch?)
- What would a new shifter do for my car?
- Wiper problem help!!!
- pa inspection
- Anyone know A/C?
- What could be wrong with my car? it Died at a stop sign...
- please help me out
- What size socket for battery?
- 115MPH Speed Limited LT1 M6??
- Radiator Rebuilt Worth it???
- state patrol issued camaro
- foglight holes = ram air?
- '95 Z28 Speedo Problem
- T/A headlight
- A/C Wont Work Plz Help
- someone help me quick? bad clunk... leaving for 1,500 mile roadtrip in 6 hours
- questions about this idea i've got
- How do I find out original dealer cost of slp options?
- Advice for First-Timer
- Broke fuel pressure gauge.. help
- Big problem with power window wiring?????
- what usualy causes the fuel gauge to not work
- Ways to cut weight
- 96 Z-28 tailights in a 99?
- Keyless entry part duex (Shoebox??)
- 2 bent drive shafts???
- Fixed slipping Stage 3 and battery drain
- Deep Hole
- Inspection done on a 00' SS... Your opinions?
- Car will not shift out of first and no speedo.
- light front left impact cause a radiator leak?
- Can't put door back together.
- strange ignition switch problem
- Left blinker doesn't work
- Speedometer Failure...
- Exhaust question...
- Need help quick!? keys locked in car.
- to buy or not to buy
- Fuel filter problems, please help
- t- top plastic panel problem
- headliner problem
- Gauges dont work
- Torn front cover help
- Mufflex Y-pipe and Jet-Hot LTs
- Taking apart lock cylinder?
- SLP air bellow and VR velocity stack questions
- Opinions on HOT or COLD oil changes.
- Firebird headlight wiring......
- what size torx bolts for the rear seatbelts?
- 3rd and 4th Gen suspension interchangability?
- Another 'removing heat fuse fixed my window motor'
- traction control
- Will this hurt my car if...
- describe "clutch chatter" please
- Get long Tubes on 94 T/A Yes or No
- Need to know how to remove all windshiled wiper plastic guards/mills
- Horn problems help
- How to paint intake?
- researching header bolts.....quick question...
- daytime running lights for 96?
- Rear Seats
- Replacing AC filter?
- Door lock actuator ?
- Interior part numbers?
- Convertible top labor charge
- Side view mirror help...
- Dyno Numbers
- Does anyone know any Duct Work sites?
- Replace Cluster 95-00
- Is There Anyway To Modify The Driver Seat To Go Back Further??
- water burning out front running lights-best way to fix
- I am new and need some advise
- A4 and m6 camaro
