Car will not shift out of first and no speedo.
I last drove the car in October. On the way out the belt broke and I have to bring her back home. Got it home with no trouble and with the holidays (we have a retail business selling pocketbikes, so it was a very busy time of year) I just did not have time to get it back on and running.
Fast foward to now, actually about a mont and a half ago. I go get a new battery, install the belt and fire it up. I take it down the driveway and get NO SPEEDO reading. The car will not shift either. I removed the VSS, cleaned it, no change. I have replaced the VSS as well, still no change. I have looked over the wires for "critter" damage and have found none. I took the battery wire off to reset the PCM and still NO LUCK.
There is no "check engine" or "check guages" light while I am driving, so I am assuming there are no codes.
What is going on?!?!
Re: Car will not shift out of first and no speedo.
No codes are showing up with TTS or Freescan. Just hooked it up a second ago.
I did not use TTS to capture the transmission data though.
My brother's 95 Pontiac did the exact same thing 2 weeks ago. We replaced the VSS to no avail. It ended up being a broken wire between the VSS and PCM.
Get out your multimeter and trace those wires.
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
