White smoke at startup,once in a while..
Old May 12, 2005 | 01:57 PM
V8 Slayer's Avatar
Only smokes briefly for a second.What could be the problem? Serious? Normal?
91 V6 Bird
Old May 12, 2005 | 03:05 PM
Mikey97Z's Avatar
Re: White smoke at startup,once in a while..
Sometimes caused by oil leaking past the valve seals when the engine's off. It's somewhat common on high mile engines. When you start the engine it burns off the oil real quick. I don't know of any serious consequences though.
Old May 12, 2005 | 03:09 PM
Runin2Nite's Avatar
i dissagree oil NEVER burns off white. White smoke is water. you probly have a little bit of water in you intake, no biggie. if it was blue then its oil, and what Mikey97z was talking about was bad valve seals. and the breif smoke is present until the seats expand from the heat of the motor.
Old May 12, 2005 | 03:16 PM
V8 Slayer's Avatar
Thanks for the answers guys..Thank god its no serious problem.
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
