Turn signal and brake light broblems
Alright, Last week it rained in my area alot. and i noticed that my driver side rear lens was flooded. All of the light bulbs also went bad. So i took off the lens, drained it out, found the leak and sealed it with silicone. Before i changed the bulbs i let it dry out. I replaced all of the bulbs and the brake light and turn signal still do not work. The other two work fine. Does anyone know why this is?
Re: Turn signal and brake light broblems
Ok i changed the bulbs again. The turn signal still does not come on when im driving, nor does the brake. But when i hit alarm button all of the lights in the back go off. Anyone know why this is?
I have quick question:
How do you change the front turn signal/parking light bulbs on a 2001 Z28?
I just recently got the car and one of the bulbs isn't working. I checked the manual and it's not in there.
Can someone please post how to do it step by step or post a link that shows how it's done?
Thanks.
Thanks.
Have you checked your fuses? You might have blown a few and that could be why your lights arent working.
As for the signal light, I would imagine it changes from under the hood...
If you just look around you could probably figure it out.
stangspank
Nov 13, 2015 01:02 PM
squarehead
Jan 15, 2015 07:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
