where can i buy this?
http://www.fbodymotorsports.com/inc/pdetail?v=1&pid=412
that is the part i NEED it is scratching the crap out of my window. The only problem is that I need it for a 1996!
Re: where can i buy this?
I think what's scratching your window is not the seal at the top but a rusty wheel inside your door that rolls against the glass. If you have vertical scratches in the middle of your window, chances are its the wheel.
Try any dealership.
Try any dealership.
Try any dealership.
Try any dealership.
Earlier (93-97) weatherstrips had 3 or 4 felt covered bumpers inside them approximately 1" long each. After time, the felt would come off them and the hard surface underneith would begin to mark the glass. The newer weatherstrips had a single continuous bumper integrated into them. This spread the wear over a much larger surface area and reduced the potential to mark the window. I know this because when I replaced the driver's door on my 94 Camaro with a door from a 1999 Camaro I noticed the design change.
And by the way, the part is interchangable between all years 1993 - 2002, so yes it will fit your 96.
From my GM part numbers list:
1993-2002 all F-body outer window seal on top of door
10284222 RH
10284223 LH
Current wholsale price is ~$28.50
GM parts peeps.
10284222 RH
10284223 LH
GM parts peeps.
no, i was looking for the felt covered bumbers. i found them on gmpartsdirect.com for about $6 but the shipping is $10! thanks for the part numbers from your website, shoebox. anyone know where I can get these cheaper or local?
EDIT: found them at a local dealership for just over $9 which is gonna be much cheaper than shipping from anywhere. just FYI.
Originally Posted by TABAHR
There are no "wheels" inside the door that touch the glass. The item he needs if he has vertical scratches on the outside of his window is indeed item "B" in the diagram he posted. I have completely rebuilt f-body doors and know the inside guts like the back of my hand. Rob (Shoebox) has even used some of my material on his website.
carguyshu
Jan 22, 2017 11:19 AM
warmeck
Jul 17, 2015 01:36 PM
cmsmith
Jun 4, 2015 07:35 PM
NewsBot
Jan 8, 2015 11:29 PM
