failed emissions
Old May 9, 2005 | 11:26 AM
Nickolbag95z28's Avatar
failed emissions
failed new jersey emissions. passed HC but failed the CO. i tested at 59 and the limit is 50. how can i reduce the CO. does the fact that the car has been sitting for 3 years have anything to do with it? can a tune up or something drop it to passing levels. maybe i need to clean something somewhere.
Old May 9, 2005 | 12:13 PM
bunker's Avatar
Re: failed emissions
CO means too much fuel, if you fail that and pass HC chances are you have a good cat, clean out the carbon while car running spray some carb cleaner or whatever, then change the o2's this means too much fuel.
Old May 9, 2005 | 12:57 PM
seems simple enough. thanks for the help.
Old May 9, 2005 | 05:54 PM
sir dyno's Avatar
update?
Old May 11, 2005 | 08:10 AM
would dirty oil or air filter effect the emissions at all? would any engine cleaner you dump in your oil help clean up the emissions. also is the 9 point difference a big deal or would it be easy to drop the nine points.
Old May 12, 2005 | 09:45 AM
Hyperspeed97z28's Avatar
what about a bottle of that stuff you dump in your gas that is 100% supposed make u pass emmisons ???
Old May 12, 2005 | 09:49 AM
Need4Camaro's Avatar
SeaFoam?
Old May 12, 2005 | 10:09 AM
no i forget the name of it, but it is supposed to drop so many points off your test.... its guarneteed ???
Old May 12, 2005 | 10:38 AM
Smith4046
Guest
Posts: n/a
Hey Hyperspeed;
Saw a few versions of that additive you describe. This was a few years ago, but think I was turned off by the wording on the guarantee. Things might be different now, but just think - wouldn't nearly everyone, from states who have emissions testing, be talking about how wonderful these products are?
At least that's my slant. Good luck to you.
Steve
Old May 12, 2005 | 10:50 AM
in all seriousness, since my car was sitting for 3 years and hardly driven would any of those cleaners help out a little bit? maybe dry gas. i only tested 9 points over. i dont really know how much of a difference that is.
Old May 12, 2005 | 02:37 PM
Johnny-Z-Man's Avatar
How many miles on the car?
If you have over 60,000 miles it's time to change the o2 sensors.
Old May 12, 2005 | 02:40 PM
OBE1 95Z28's Avatar
Here's a good "read" on the topic:
http://www.popularmechanics.com/auto...t/1272536.html
Old May 12, 2005 | 03:15 PM
Runin2Nite's Avatar
sitting for 3 yrs?!?! is it fresh fuel in the tank? run that bitch on premium burn off what you can
Old May 12, 2005 | 04:31 PM
Z06Z28's Avatar
My 88 dodge diplomat was sitting for over 9 years and passed smog just after two hours of running it on the freeway to get it warmed up. It was weird, black smoke was heaping out the back and then went away after awhile. I stilll have no idea how it passed smog the first time. I wonder if it's because it has 5 Cats on it. lol
Old May 13, 2005 | 09:44 AM
its at 66k miles now. it was a fresh tank. i was driving it for a few hours before i brought it in. a little black smoke but it was gone before i got it tested.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Boss002
Jul 24, 2015 10:47 AM
