Shims with poly trans mount?
Old May 12, 2005 | 11:25 AM
convertz's Avatar
I just put a poly trans mount in the Z28 and now I have this vibration at 55mph. The mount seems to be softening up and getting smoother but it still vibrates at 55.
I hear that the mount is taller, so you have to shim the cross member down a bit to correct drive shaft angle. How far do I go? A washer or two good enough?
thanks
-Ted
Old May 12, 2005 | 04:35 PM
Z06Z28's Avatar
Re: Shims with poly trans mount?
with a poly transmount your ganna feel a lil more vibration due to the poly mount. As long as it's not clunking like if it was broken or loose bolt. If your worried about it, check the bolt after a few miles and make sure it's tight to ft lbs specs. I never heard of a shim being used but if my memory serves me..you do use a washer on the outside bolt.
Old May 12, 2005 | 05:38 PM
FastrDamnit!'s Avatar
If it's the Energy Suspension (probably most common one) one just don't use the metal plates that come with the kit and shave the two pre-load bumps on the mount down and you'll be fine. No vibration from mine.
Old May 12, 2005 | 06:57 PM
CamaroSS30thAnn's Avatar
they do make a poly mount specific for our cars , not sure which one it is ,
the vibrations are not that bad, its a sports car arent vibrations and loud sounds a part of life
Rde Bandit
Mar 21, 2015 10:17 PM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
