SES light
SES light
Ok i have a 94 z28 and the ses comes on after about 15 minutes of driving and stays on for about 5 mins then goes away. It seems to be happening everytime i drive the car after 15 minutes. My question is will the code still show up after the light shuts off when you scan. It would be hard to catch it and go and get it scaned before the light shuts off again.
Any ideas of what might be causing this without getting it scaned. Doesnt seem to run any differntly at all with it on or off just the fans turn on??
Re: SES light
Yes, any code will be stored, even if the light goes off. It will self-clear after about 50 drive cycles without the same problem happening again, but it sounds like your problem is recurring.
Re: SES light
You asked for a guess and here is mine. I have a similar problem where the SES comes on and then goes away. It is the EGR on my car that is causing this to occur. Usually it happens when I get stuck behind someone driving slow enough to cause me to be between gears. Too slow for third and too fast for second. Once I get out from behind them and open up, the light generally goes away.
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
